SFR-FON again (1 Viewer)
OldAgeTravellers
1,207
1,387
Telford, UK
Since 1970
Hi,
I have been using the Solwise 11n3G-USB_Router with the Rocket Ariel very successfully to connect to McD's etc. for some time and am very happy with it, but recently I have been using the SFR-FON network in France.Although I can get a good signal and connect with the router I can not get SFR to push the sign-in page to be able to use the router wifi within the Motorhome. But can connect directly and easily with the iPad phone or laptop if I can get close enough for a good signal.
Somebody on one of the forums of which I am not a member so cannot post has suggested some of the router settings need changing. Steve Mace at Solwise thinks SFR detect that a router is trying to connect so will not push the sign-in page.
Adam at MotorhomeWifi in his excellent article Broken Link Removed suggests that their iBoost which is similar to my setup can be used to connect.
Has anybody had the same problem and found out how the settings should be changed?
Thanks for any help you can give.
Steve
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
My router connects ok but if the db figure is too high the log in page won't appear. Need to be fairly close without trees
Feb 16, 2013
19,734
52,019
uttoxeter
ambulance conversion
50 years
Have been trying to use fon for three years now, done every tweak that has ever been mentioned, iv opted in and out till I'm blue in the face , but still can't get any sense out of it, sometimes it connects but I never get the sign in page , iv give up on it and use whatever wifi is available , usually some connection somewhere. Mind you, I see you live in France so you should have the proper fon , I'm talking about bt fon.
Welsh girl
3,658
3,036
Globecar
Since 2004
Iw found the same with the iboost. Adam at motorhome wifi had been most helpful but unable to rectify this.
It's the 2 stage sign on that does it. The iboost gets the signal but then it won't load up the Google Web page to enable me to sign on.
He's going to have to iboost back to configure it when we're get back to the uk.
Meanwhile back to the 'hoping 'I'm in range with the tablet! !
SandraL
1,373
985
Somerset
Hymer b694sl
OK, I have an alfa r36 which I think is the same as your Solwise. I had problem that router said connected but I never saw the SFR site. The R36 is sent out with 192.168.2.1 as the address at which you log on with your tablet/pc. This clashes with the SFR address sent by the SFR site, which you cannot alter. I have changed my r36 router log on to 192.168.168.1 As soon as you do this you need to log on to router again using new address of 192.168.168.1. This no longer clashes with SFR address and R36 shows connected ( as before) but actually allows me to connect to SFR. It worked for me, good luck.
OldAgeTravellers
OldAgeTravellers
1,207
1,387
Telford, UK
Since 1970
Sandral, thank you, instant success. If we ever meet I owe you a very large beer or three. I am now connected with the router, SWMBO is happily working on her IPad I am working on mine and BBC Radio is playing in the background from my phone, all connected to the wifi router which is in turn connected to SFR-FON. Sitting in the van on the outskirts of a village with three SFR-FON hotspots over 300 mtr away. BRILLIANT. Is there a bouquet of roses feature on FUN?
Lenny HB
53,421
149,949
On the coast in West Sussex
Hymer B678 DL
That sums it up I had the same problem last year in France.
French Fon routers push out an IP of 192.168.2.80 with a gateway of 192.168.2.81 so the WAN is in the same range as the LAN.
I would recommend you change the LAN address to something in the 10.0.0.0 range such as 10.0.0.254, reason I suggest this is so you don't do what I did, that is change it to 192.168.1.254 then found I couldn't connect in the UK took me a while to realise same problem reversed UK Fon are in that range.
Lambchopuk
3
UK
Chasson
Since 2013
I wonder if any of you can help me. I've followed this thread with interest as I have a Solwise 11n3g router and rocket which I tried to use with little success in France last year on SFR Fon .
When I tried setting the LAN to 10.0.0.254 (at home, in UK) I had the following error:
Incorrect ! Lan ip in DHCP lease range.
Any advice? Thanks.
Lenny HB
53,421
149,949
Hymer B678 DL
Look at the address bar in your browser, you are trying to log onto the router at 192.168.3.1 instead of 10.0.0.254
Lambchopuk
3
UK
Chasson
Since 2013
Hi, 192.168.3.1 is the existing LAN and I am trying to enter and set it to 10.0.0.254. When I hit apply I get this error.
Lambchopuk
3
UK
Chasson
Since 2013
I've set the lan to 168.168.168.1 as suggested in an earlier post and I am able to still connect to my neighbours btwifi-with-fon via the solwise router here in the UK as I could with the default lan address. The test will be if it works when we head to France this summer.
Kevin
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
OMGG! :)
At least I now see why I had a problem in France last week...as for sorting it out!
Techno
Jul 28, 2010
15,475
20,756
May 2010
What do I need to change here to get the SFR log in page to come up ?
Never had an issue here before
Feb 5, 2009
678
783
South Essex
15 in MH, 15 in Caravan
Looks like your WAN and LAN address are in the same range 192.168.2
You will need to change your LAN range, but on a train right now, so can't remember off the top of my head how it's done on the Solwise
Steve
Techno
Jul 28, 2010
15,475
20,756
May 2010
SORTED!! thanks this worked (y)
JockandRita
11,462
150,134
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Can I ask Sandra, did you have to change the R36 back to 192.168.2.1 when you came back to the UK?
Does anyone know who BT's FON partner is in Germany please? Although I do have a MiFi with a T Mobile sim, it would be costly to try and use it, despite T Mobile being a German company.
Cheers for now,
Jock. :)
Lenny HB
53,421
149,949
Hymer B678 DL
Yes, but you can use another range so it works in both cointries I have mine set to 192.168.10.254
For Germany, Deutsche Telekom WiFi Fon hotspots.
SandraL
1,373
985
Somerset
Hymer b694sl
No, I didnt change mine back, its still on 192.168.168.1 and it works in UK and france. Good to have info re germany though, thanks
Mr Mousy
620
3,105
Llanelli
Hymer S840
First moho 11/2013, second 11/2014 current from 09/2019.
Thank you all - I changed to 192.168.168.1 and everything was good from there.
