Sewage dumping problem
Discussion in 'Motorhome Chat' started by Cat53, Jul 30, 2016.
  1. Cat53
    Cat53 Funster
    Feb 22, 2014
    1,091
    5,471
    Grantham
    Winnie has a built in sewage tank which works wonderfully well providing the dump station is in the ground. It's gravity fed, not pumped. You just attach a bayonet hose, open the grate on the sewer, put the other end of the hose down the hole, pull the lever and the tank empties. All wonderful. Except on sites when the chemical waste dumping station is built above ground level. Then it doesn't work. So what do you do? Assuming your toilets are not cassettes.
    • Like Like x 1
    • Useful Useful x 1
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,335
    7,458
    Nr Watton in Norfolk
    Empty into a cassette or a bucket .........
    • Like Like x 4
  3. campa cola
    campa cola Funster
    Oct 5, 2012
    2,908
    5,796
    Weegeland
    Probably about 90% of the sewage disposal I encountered in Europe was above ground level. One of the few that was not (in a marina) used a kind of scoop fitted to a vaccum pump !!!
    • Like Like x 1
  4. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    774
    469
    Cornwall/France/Spain
    • Useful Useful x 2
    • Like Like x 1
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,521
    9,942
    a macerator and pump or "bucket 'n' chuckit"
    • Like Like x 1
  6. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    189
    91
    Sussex
    I think Caktanks do an adaptor to take a cassette.
    I assume you can then discharge a limited amount of your tank into the cassette and then discharge at the above ground facility.
    I don't know how well this system works but I can see it all ending in tears :notworthy:
    • Like Like x 1
    • Funny Funny x 1
  7. Tootles
    Tootles Funster
    Sep 14, 2013
    9,135
    32,604
    Lancaster
    Easy.(y) go into the loo, assume a kneeling position, ensure that the pipe is in place, and that the valve is open, then blow steadily into the pan. (y) Constant blowing will ensure a steady flow from the outside.:)
    CAUTION. Under no circumstances be tempted to suck.:cautious::(
    • Funny Funny x 9
  8. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    893
    559
    Falmouth, Cornwall
    As suggested a macerator, they will pump a long distance; make up a short pipe to the pump and then 1 inch pipe to connect to the difficult dump options. I don't have any pictures but there has been someone on here with a Concorde who did a similar thing I will see if I can find it.
    • Like Like x 1
    • Thanks Thanks x 1
  9. sallylillian
    Oct 29, 2011
    893
    559
    Falmouth, Cornwall
    • Like Like x 2
    • Thanks Thanks x 1
  10. Cat53
    Cat53 Funster
    Feb 22, 2014
    1,091
    5,471
    Grantham
    • Like Like x 2
    • Informative Informative x 1
  11. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,786
    13,700
    Norfolk
    With our RVs I used a fiamma tote tank with 3" bayonet fitting so where no ground level dump wheel it to the elsan point.
    • Thanks Thanks x 1
  12. chaser
    chaser Funster
    Feb 16, 2013
    7,480
    8,417
    uttoxeter
    There's usually a manhole cover somewhere near, just put your pipe down there.
  13. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    5,939
    11,313
    East Sussex
    What if it's a rainwater drain rather than a sewage drain ?
  14. chaser
    chaser Funster
    Feb 16, 2013
    7,480
    8,417
    uttoxeter
    Oops :Eeek: too late;):)
    • Funny Funny x 4
  15. PeteH
    PeteH Funster
    Nov 22, 2007
    2,100
    2,634
    East Yorkshire
    Ok. So having had many experiences of this (Espania) There are several "methods" I had a Macerator pump which was capable of achieving some level of Above ground discharge. OR I purchased a "roll tank" into which the "debris" was discharged and disposed of as per "cassette". I still use said tank as "grey waste provider" on the current "euro-box"!!. Fiamma product and excellent in my view!
    Pete
    • Like Like x 1
  16. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,786
    13,700
    Norfolk
    As post #11 fiamma tote tank ;)
    • Like Like x 1
    • Thanks Thanks x 1
  17. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,601
    1,662
    Stretford
    Seems like a pain the Harris theses fixed tanks if you haven't the facility to empty them, not only that you have to carry round some sort of pipe with fittings full of Pooh in your M/H or empty the turds into a bucket without spilling anything and carry across site :eek:
    • Like Like x 2
  18. Bart
    Bart Funster
    Jun 4, 2016
    1,713
    497
    N.Ireland
    Yip sounds like a pile of shite......
    • Funny Funny x 2
  19. Cat53
    Cat53 Funster
    Feb 22, 2014
    1,091
    5,471
    Grantham
    The piping isn't a problem cos you do the sewage first and flush through with the grey water, plus I use rubber gloves. It's quick and easy. Being a novice in all things motor homes I was surprised by the novel variety of sewage disposal. Who would have thought there were so many ways of getting rid of it!
  20. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,065
    13,079
    Ramsey, Isle of Man.
    A macerator..............starspangledspanner.co.uk
    Craig
    • Like Like x 2
