Setting up Alfa R36 with Alfa USB adapter (1 Viewer)
Dai Motorhome
151
19
Burnham on Sea, Somerset
a class
Hi I'm struggling to set up my new gadget, an Alfa R36 with an Alfa awus036nh adapter. Get partway through the setup but stuck when it asks to do a 'site survey'. Nothing comes up. Anyone any ideas?
thanks
David
freelanderuk
1,018
534
Saltfleet/Lincolnshire
c class
Make sure you plug your Ariel into the r36 before powering on the r36 , when plugged in you should get 3 blue LED's lit on the r36 then do a set up using set up wizard , follow instructions and the r36 will reboot and reconnect you should then have a WiFi signal ,
The site survey should find any WiFi signals in your area , if it picks up nothing make sure the Ariel led is lit
I just noticed that you are using a n Ariel , have you updated the firmware on the r36 as I think it comes as standard for b and g signals
D
Dai Motorhome
151
19
a class
Got the firmware upgrade and then could see the AP' s available. Chose my home network and selected it. My laptop now shows it's connected to the R36 but tells me there's no internet connection!!:Angry:
D
Dai Motorhome
151
19
a class
well finally waded through all the settings and got the router and adapter working. Am i going to have to go through this process every time I want to log into a new network? Will it work on a caravan club site logging onto their network?
cheers
David
