Service warning Light (1 Viewer)
Aethelric
13
6
DUNFERMLINE
Auto-sleepers Nuevo
Since 2008
I have just had a 25000m service done on my peugeot boxer based auto-sleeper nuevo.
I was expecting the service light (an illuminated spanner) to be out after the service but its still on. The mechanic said it would go out in a few hundred miles. Its done around 24500 so far.
Is this normal - does it go out by itself after a certain mileage?
Dave
haganap
12,758
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
what van is it? you can turn them off yourself on the older ones....In fact I think you still can on the newer ones. :thumb:
its a combination of things you do
Merle
424
226
Wiltshire
Since 2008
Dave
I reset mine manually, sorry I can't remember what I do but it is in the handbook. I will look it up tomorrow if no one has told you how before
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
The manual has something in it about resetting the spanner. You have to put the ignition key to a certain position (can't remember which) then hold down the trip reset button for 5 seconds. That is on a 2006 Boxer. I'll know if it works after I try it when I service the van.
MikeD
3,936
3,697
London
IH PVC
Since 2012
In my understanding most of electronic systems that monitor your engine sample the system each time they start.
If all is ok they do not show warning lights, even if a problem occurs some will not show a warning light unless it re-occurs for a few starts.
Some will show a warning light but if the next "set number" of starts do not show the same problem will switch the light off.
But I have never heard of one that switches a service light out. That is usually done by accessing the system with a computer and switching it off manually.
:thumb::thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
You paid for a service, resetting your service indicator should be a part of that. Use a better garage
A
Aethelric
13
6
DUNFERMLINE
Auto-sleepers Nuevo
Since 2008
Thanks for all the suggestions folks but non of them worked. But the light went out by itself after a few hundred miles, as the mechanic said it would. :Smile:
