Service oil now? (1 Viewer)
Biged
159
70
Nottingham
No longer looking
newbie
My van is Transit based 2007 2.4 with 12500 miles on.
The oil (fully synthetic) and filter were changed early this year, only 3000 miles ago, this morning going to fill up for our impending trip to Dorset the Info panel came on with service oil now, any ideas?
Feb 16, 2013
19,699
51,878
uttoxeter
ambulance conversion
50 years
Is it low? Have you looked at the dipstick, sorry if this sounds rediculas but you don't say
Biged
Biged
159
70
Nottingham
No longer looking
newbie
Yes, should have put that its near the top of stick so used very little in the 3000 miles and relatively clean for a diesel.
Feb 16, 2013
19,699
51,878
uttoxeter
50 years
Perhaps a wire come off the sender, or something like that
Apr 9, 2013
663
373
Ayr
Newbie
It's possible that it's just that the computer hasn't been reset at any of the services and it thinks it's due its first oil change.
I would phone the garage that does the servicing and ask if they reset it at the services.
gradyp
311
306
Widnes
Elddis Supreme 155
Just googled this
Want to reset your transit service light yourself ? Ok, with your ignition off press the brake pedal and Accelerator pedal down at the same time .Now turn your ignition back on but do not start the engine KEEP THE PEDALS PRESSED DOWN the service spanner light will go out, keep the pedals depressed for aprox 30 seconds or untill the light pops back on and flashes.
Take your feet of the pedals turn the ignition of then back on. Your service light will go out and stay of for another 15000 miles."
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
The above sounds the correct advice but failing that escorts used to do that if you parked it on a steepish slope and started it. the next time you start it on the level it may not come on.
Biged
Biged
159
70
Nottingham
No longer looking
newbie
Sorted it (y)
Tried the method that helpful people have posted but that did not work.
Went on the Transit forum and the method is slightly different but worked.
This is copied and pasted from the site.
To switch off the service light in your MK6 or MK7 Transit:
1. Service it
2. Switch on ignition but don't start engine
3. Press Down Brake pedal and Throttle pedal fully, and hold till service light flashes this may take up to a minute, but usually about 15 seconds
4. Switch off igniton
It should be done with the ignition on and mine's not a light but a warning. When both pedals are pressed the screen changes from 'service oil now' to 'reset in progress' keep pedals pressed until screen reads 'reset complete'
Great thing this internet :)
sean n maggie
672
327
leeds
autotrail
Best ÂŁ10 you ever spent joining then.....:rofl::rofl:
