Sensor problems (1 Viewer)
Apr 26, 2012
95
8
Newbie
We have a swift kontiki 669 on a 12 plate the waste water sensor is reading full when it's empty any ideas anyone :thumb:
TheBig1
17,630
43,276
its a very common issue, as the sensors in the side of the tank get dirty and start corroding. a temporary fix is take off the inspection hatch and clean the sensors, but the problem will come back
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Best thing to do is disconnect the wiring from the waste tank sensors and then empty it everytime you fill the fresh water tank, or sooner.
Our waste tank shows full when empty and anything in between. The tank and sensors have been cleaned already about a month ago and it is reading full again. The van is 4 months old.
I have just emptied a litre of Fenwicks tank and waste cleaner in a half full tank to see if that does anything after a good drive around, but this is a common problem.
Allan
Mike Eldridge
5
Rochester
Swift Kontiki 669
since 2008
Hi All, just joined this site. Been touring for a few years and have now upgraded to a MH
I have a kontiki 669 with a couple of issues, the first is the waste tank sensor reading full all the time. Is this an easy part to fix, also looks like the air con unit thermostat is also playing up as the temp will not increase just remains a cool, but not cold. again has anyone got any advise in changing the thermostat. Also can any one explain the cabling set up for the roof Satellite system as we can get the TV's to tune in
Many thanks
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Many thanks
Hi Mike, you are best to start your own thread under the technical section. Welcome to the forum.
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Check the other post you made Mike ( in the techy section ) I have made a fairly comprehensive reply for you :)
