Semi Flexible Solar Panel - any good? (1 Viewer)
ShiftZZ
21,383
84,501
Dark Side of the Moon
120W 12V Semi Flexible Solar Panel For RV Boat Battery Charging Caravan HQ Smart Car
Feature:
120W 12V monocrystalline semi-flexible solar panel.
Light weight, easy to carry.
High conversion rate, high output.
Resistance to resistance, can resist different environment, waterproof performance is good.
High stability, good durability
With Sunpower chip, can be used for car ,home, boat, motorcycle, etc.
Suitable for car batteries, car, RV, boat, ship, aircraft, satellites, space stations, outdoor breeding, planting, tourism, solar street lamp.
Specifications:
Size: Approx. 1180x540mm / 46.4"x21.2"
Power: 120W
Working voltage: 12V
Operating temperature: -40℃ to +85 ℃
Length of cable: Approx. 1m/39.3"
Weight: 2500g
Package includes:
1 x 120W 12V Monocrystalline semi-flexible solar panel
Lenny HB
53,321
149,522
On the coast in West Sussex
Hymer B678 DL
From what I've seen on the forums a lot falling over after not much more than a year.
Not much point in buying an inferior product for more money than a proven standard one.
Oct 8, 2009
484
352
Kent
Sunlight
32 years
I previously had a 100W version of this and used to pop it onto the roof through the large vent or use it on the ground propped up to face the sun. Mine was quite light so I think it would have been ok lying on the awning but that would restrict how long it faced the sun unless you moved the MH around.
