Security Door Lock
Discussion in 'Motorhome Chat' started by ShiftZZ, Dec 15, 2013.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Milenco or Fiamma
    Opinions?
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,941
    First action is to reduce the choices to those models which can actually be fitted. For instance, is there a fridge or other appliance in the way which prevents the device being fitted to the wall.
    • Like Like x 1
  3. ivorantony
    ivorantony Funster
    Jan 22, 2013
    508
    538
    London SE
    I fitted four of these locks to the MH this year and very pleased with results,
    You can see at a glance that they are locked, very robust and well made,
    Would highly recommend them, just a satisfied user,
    http://www.imc-creations.fr/Verrou-Cellule
    • Like Like x 2
  4. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,772
    Narrfoook
    I fitted a Fiamma.. It is 'ok' but thats all I will say.
    I have no experience on the Milenco locks but on the whole Fiamma is lower end of the spectrum and Milenco upper end.. Every product we have bought from Milenco has been very good, pretty much everything from Fiamma has at best been adequate
    • Like Like x 2
  5. greygit
    greygit Read Only Funster
    Aug 11, 2009
    274
    232
    Forest of Dean, Glos, France and Spain
    Aren't the locks on the hab door a bit pointless as the easier access would be through the cab driver or passenger doors?
    • Like Like x 2
  6. chaser
    chaser Funster
    Feb 16, 2013
    7,505
    8,479
    uttoxeter
    Or the plastic windows:Sad::Sad:
    • Like Like x 3
  7. Jim
    Jim Ringleader
    Jul 19, 2007
    26,426
    78,071
    Sutton on Sea
    No not really, the habitation door is as often used as the cab doors because its normally so easy to open. You can open it with a screwdriver quicker than with a key.
    Yes the acrylic windows might be a weak point but its very rare for a burglary to be effected through one, if they are going to break a window then its normally the quarterlight.
    • Like Like x 2
  8. paulmold
    paulmold Read Only Funster
    Jun 15, 2009
    895
    301
    North Wales
    Both brands do adaptor kits to enable the locks to be screwed to the door frame instead of having to drill through walls.
    Edit - sorry, the kits are for the fold-over handle type lock, both make specific locks for frame fitting
    http://www.ebay.co.uk/itm/Fiamma-Sa...ervan_Caravan_Accessories&hash=item2a34f07ec5
    http://www.ebay.co.uk/itm/MILENCO-D...ervan_Caravan_Accessories&hash=item35cf6814e8
    • Like Like x 2
  9. GJH
    Aug 20, 2007
    27,346
    34,941
    • Like Like x 1
  10. hilldweller
    Dec 5, 2008
    27,274
    26,271
    Macclesfield
    Whatever you fit do not do anything that will prevent you getting out or emergency services getting in the event of fire or accident.
    We did have a member that locked themselves in by leaning out of a window and setting one of these locks.
    • Like Like x 2
  11. wasp
    wasp Funster
    Dec 21, 2008
    2,730
    1,066
    Mansfield
    I got a Fiamma one as others say it is adequate I haven`t suffered a break in fortunately:Smile::Smile::thumb::thumb::thumb:
    • Like Like x 1
  12. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,641
    14,312
    North Lincolnshire
    I fitted a Milenco one.
    Fitted it meself and broke nowt!
    Easy to fit, two bolts screwed into the door frame.
    They can be locked in the "open" position, needing the key to re open them.
    That being the case, as long as the lock button is pressed when it's opened there is no danger of locking yourself in.
    • Like Like x 1
  13. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,483
    1,333
    SW Northumberland
    Bought and fitted Fiamma safe door locks to garage doors, well pleased. Managed to purchase a pack of 3 on an Ebay auction for £75 so I have a spare but more importantly all 3 locks are the same key.:thumb:
    • Like Like x 1
  14. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    I've just bought one of these off eBay I'll let you all know what I think when it arrives.:Smile:
    Item 111238150704
    • Like Like x 1
  15. Mel
    Mel Funster
    Oct 6, 2012
    2,103
    2,121
    De Haan Belgium
    • Like Like x 1
  16. hilldweller
    Dec 5, 2008
    27,274
    26,271
    Macclesfield
    That is excellent.
    We've got the Fiamma one an outside locker ( because I found it open one day, probably me not shutting it properly ) and that can't be locked open, so on the hab door some wag could easily just rotate it for fun and lock you in. It is years old now and works just like new.
    • Like Like x 1
  17. Ber090
    Ber090 Funster Life Member
    Dec 12, 2012
    497
    496
    N Yorks
    Meor, We have a thule that I think is very good but surprisingly it has Milenco stamped inside!
    Bernie
    • Like Like x 1
  18. iandsm
    iandsm Funster
    Jan 3, 2008
    1,633
    2,778
    Suffolk
    Very nice piece of kit, where did you obtain them please?
  19. Mel
    Mel Funster
    Oct 6, 2012
    2,103
    2,121
    De Haan Belgium
    Yes they are the same.
    I had milenco on my caravan
    I presume Milenco is another firm thats now in the hands of giants.
    Mel
  20. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    What about fitting an Abus deadlock - visually much less intrusive and it does not signal whether you are in or out as the external Fiamma type does (i.e. if it is in the unlocked position - you are inside, but when it is closed, the motorhome is empty).
