Securing A Table? (1 Viewer)
Oct 1, 2013
7,503
19,905
Lanzarote
Nil by mouth
Lots
In my conversion, there is a free standing table which folds away.
But when I had the conversion done, it was stipulated that it must have a fixed table, to be re-classed as a camper. Hmm.
If I apply fittings to the rear doors for the table to attach to, will this class as fixed ?
Well, still gonna do something, so how can I fix it to wall/door?
I can't think of any fixings that will allow table to fitted to, and then allow it to be stored away when not in use .
Any ideas ?
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
I don't think that's correct.
A fixed table is not an absolute requirement for a class of 'motor caravan'
norrie14
56
28
glasgow
roller team
table
hi I done a conversion about 2 years ago I just put up a fold away wooden table stood it next to seats took photos but did not show it was not fixed photo just above floor had no problem
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Standard on Burstners - a 12mm tube mounts on the wall spaced off by 6mm. The table has plastic hooks, C like with slide locks. Then one leg to floor.
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
Our table isn't fixed, it stows away in a locker.
It is also free standing so that we can use it outside as well.
This is as it was from the manufacturer.
Yorick
Oct 1, 2013
7,503
19,905
Lanzarote
Nil by mouth
Lots
Yeah, that's what I did :ROFLMAO:
Just wonder what will happen if I need to make a claim or summat ?
The pics I sent were for the DVLA. Will it appease the insurance ?
Minxy
32,624
66,459
E Yorks
Carthago Compactline
It is for a conversion.
I've just Googled the VOSA requirements and came up with the below webpage:
https://www.gov.uk/government/publications/guide-to-the-individual-vehicle-approval-iva-scheme
It has a pdf file for download giving details of the IVA requirements under Annex 3 - Special purpose vehicles & their definitions (page 52)
Motor vehicles of category ‘M’ (only) constructed to include living accommodation which contains at least the following equipment :
• seats and a table,
• sleeping accommodation which may be converted from the seats,
• cooking facilities,
• storage facilities.
This equipment must be rigidly fixed to the living compartment, however the table may be designed to be easily removable.
So the FIXINGS for the table have to be permanently fixed to the vehicle now, but the table can be removable. :Smile:
sedge
Jul 7, 2009
5,502
13,085
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Yes in the case of the 2009 Swift Bessacar we just P/xed in March, the fixings for the freestanding table were on the LHS inside wall of the wardrobe. You closed it and stowed it in the wardrobe against the wall !
:ROFLMAO:
Where does it say 'fixed whilst in use' ? - it doesn't !!
Yorick
Oct 1, 2013
7,503
19,905
Lanzarote
Nil by mouth
Lots
Great, it seems that it can be packed away :Smile:
Now, just need to find the best way to attach to wall :winky:
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
drop the head waiter a tenner, works for me::bigsmile:
Minxy
32,624
66,459
E Yorks
Is it just me or are men unable to think 'outside the box'?!?!?!?! ::bigsmile:
The part that attaches permanently to the wall/doors is just a pole with ends on that fix it in place (plus a central fixing piece too) ... there's nothing special about it at all! So, you could:
Cut the pole in half (or smaller if necessary) and get 2 more end fixings of some sort and fix put one piece on one door, and another piece on the other door, at the right height for the fixings to sit on and be secured as you woudl normally.
Alternatively do away with the original pole and get some sort of suitable replacement, or just buy the clips and make your own:
http://www.olearymotorhomes.co.uk/table-bar-clip-946-p.asp
or just get some 'basic' type of fixings which the table would hook on to:
http://www.olearymotorhomes.co.uk/brown-holder-table-bracket-949-p.asp
another of the 'full kits':
http://www.olearymotorhomes.co.uk/table-wall-bar-set-945-p.asp
also the below is described as a table leg kit, but from what I can tel it is a rail that you attach to the wall with another that slots in, and therefore could be cut to length and fixed easily:
http://www.olearymotorhomes.co.uk/brown-table-leg-kit-61cm-2167-p.asp
Minxy
32,624
66,459
E Yorks
:ROFLMAO:
But you are talking about a vehicle built specifically as a 'motorhome' (be it a coachbuilt or PVC) and first registered as such so not registered as a van previously. This is about changing the classification from a van to a motorhome/motorcaravan and that requires 'proof' of changes to the vehicle to enable it to meet the criteria for the reclassification and be approved as such. Therefore I don't think the table having to be fixed in place to 'use' can be a requirement for vehicles first registered as motorhomes as they were intended to be that from the start and so will have met the criteria for that classification already otherwise they wouldn't be motorcaravans. :Smile:
