'Secret Switch' immobiliser (1 Viewer)
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
best way is to immobilise the engine by putting a secret switch on the fuel cut off solenoid, it will never start and they would have to tow it away!
Currently looking into additional security and found this buried in another thread about wheel clamps. Like the sound of it but have no idea how to fit it. Is it only a DIY thing or could I get one fitted by someone who actually knows what they're doing? :RollEyes:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Simple diy job or garage will do it for you :thumb:
some soleniods are buried in the fuel pump so difficult to get at directly but find the wireing that goes to it, with ign on find the live one and cut it
run both cut ends to a suitable hidden switch and its done:winky:
Just dont forget where you hid it:Doh:
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Possibly better than a secret switch would be to put a fuseable link in the live feed, then all you have to do is take the fuse with you in your pocket and replace when you're back in the vehicle. The fuseable link would then not need to be so hidden as a switch.
1,622
280
Five Roads Alyth
A class RV
since 2005
Personnaly, stick with the switch if that's what you fancy, fuses are not realy meant to be moved constantly and can and will break.
Chani
124
7
Somerset
We fit these to our vehicles:
Link Removed
You can also attach the key to your keyring so there's less chance of losing it.
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Link Removed
Any self respecting thief would just wrap a bit of wire around the connections and off he goes.........
Doug...
Douglas
2,835
400
South Wales,
Only if he can find it ...
True, but if he is under the bonnet trying to get is going he stands a good chance of spotting the nice big switch, they might be low life's but not all of them are stupid.
Doug...
43,302
49,289
used to have a very similar item bought in south africa.
simply 3 'normally open' relay's in a fancy black box.
trace fuel pump live, cut and re-connect to one set of output wires on the pretty box.
do the same with the starter seloniod feed and, as it was a petrol car at the time, the ignition coil.
auto-arming on turning off ignition and just one 'secret' micro push button to deactivate with ignition on.
Cost......around R35........£7 at the time.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
When I bought a 1949 MG tc in the 50's it had an ordinary brass light switch in the ignition circuit.This was positioned in the footwell and couldnt be seen-you had to know where it was :winky:
Mike
43,302
49,289
Doug...
Sorry Doug, but unless the scroat intends push starting the vehicle, it would need to be more that a 'bit' of wire...it would be carrying full starter current....400/500amps.
and you aint going to just wrap that round the terminals, but i do understand what you mean :thumb:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Mike
Hi Mike
I also had a MG mine was a later model which somebody in the past had fitted a cut off switch to the ignition, I had to take it off it kept cutting in at the most in convenient times:Angry::Angry:, never did put an other one on, On the Vintage cars we had I always put a battery cut off switch to be on the safe-side of electrical faults. Pete :thumb::thumb:
Douglas
2,835
400
South Wales,
True, but I did not want to complicate the post.
I'm sure you remember when starters had an external solenoid on the starter and a screwdriver would start the engine no problem at all, didn't do the stud threads any good though.
Doug...
Chani
124
7
Somerset
Doug...
They're not under the bonnet on either vehicle, and when the key is removed it's just a black piece of plastic with a hole in the middle. Only the key is red.
maz
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Thanks everyone for your ideas. The 'secret switch' version is still my favourite and seems fairly easy to install - now I have to decide where to hide it. :Smile:
One other question has sprung to mind tho': would fitting something like this affect the van's warranty?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
They don't need much of an excuse, to avoid warranty problems a proper propriety immobiliser should be installed
If your vehicle is new enough to have warranty issues does it not already have a factory fitted system?
Geo
maz
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Geo
It's a used van but it comes with a warranty. It has a basic factory-fitted immobiliser but I thought that that would be known about by any thief, so liked the idea of an additional 'secret switch'.
