Second Leisure Battery
Discussion in 'Motorhome Chat' started by Yorick, Sep 3, 2014.
  1. Yorick
    Yorick Funster
    Oct 1, 2013
    3,998
    5,874
    Lanzarote
    Yesterday I was talking to a local man about fitting a second leisure battery to my Transit based camper.
    I also want him to fit a split relay thingy, but he said the alternator wouldn't be big enough to charge both leisure batteries.
    He suggested having 2 seperate batteries. One charged from van and one from EHU.
    is he talking bollox?
  2. Yorick
    Yorick Funster
    Oct 1, 2013
    3,998
    5,874
    Lanzarote
    And a second question. Many moons ago the van battery flattened as we left the fridge on while not travelling. Sadly the leisure battery was not man enough to jump it off.
    would this addition of a second battery provide the extra needed power to start the van in an emergency?
    Thanks.
  3. Daz n Tina
    Daz n Tina Funster
    Jan 8, 2014
    749
    1,889
    Emsworth
    with regards to the fridge the van battery should not discharge as there should be a in line relay which only allows power to the fridge when the engine is running and shuts off when the engine stops. My van has two leisure batteries and is charged from the alternator or ehu - but in fairness i dont know what amps my alternator kicks out.
  4. JJ
    JJ Funster
    May 1, 2008
    14,641
    25,978
    Don't listen to me because others know far more but...
    Your alternator can charge 2 leisure batteries but will take longer to fill them up.
    Unless it is a compressor fridge then the fridge will quickly flatten your batteries.
    The usual set up is you can only work your fridge on 12 volts when the engine is running (the fridge relay knows when the engine is running and connects the fridge).
    The second leisure battery won't help very much with jump starting unless the connecting wires are nice and fat.
    JJ :cool:
  5. DonA4000
    DonA4000 Funster
    Jul 23, 2013
    290
    164
    Scotland
    What age is your transit? You should be able to find out what power output your alternator has!
  6. Yorick
    Yorick Funster
    Oct 1, 2013
    3,998
    5,874
    Lanzarote
    Thanks. I forgot to mention that there is no fridge relay. Yet. That's next on list.
  7. Wissel
    Wissel Read Only Funster
    Sep 16, 2013
    301
    323
    Cornwall
    Yes he is (probably).
    I have a few minutes free, want a drawing of exactly what you need?
  8. Wissel
    Sep 16, 2013
    301
    323
    Cornwall
    Was bored so did a drawing anyway :)
    [​IMG]
    This will give you a split charger for your leisure batteries and power your fridge correctly on 12v (so it just comes on when engine is running).
    It will also allow you to jump the starter battery from the leisure batteries by by-passing the relay (I have a similar system fitted in my own van).
    Because of the current needed to jump start you will need 25mm cable where shown.
    Hope this helps.
    • Like Like x 3
  9. Yorick
    Yorick Funster
    Oct 1, 2013
    3,998
    5,874
    Lanzarote
    Cheers Wissel
  10. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
  11. Wissel
    Sep 16, 2013
    301
    323
    Cornwall
    Assuming you already have two batteries , so want four, it's worth connecting them in a way that charges and discharges them equally. I have four in my own build and this is how they are connected:
    [​IMG]
    What this does is splits the batteries into two banks diagonally, then joins the two banks diagonally. Looks complicated but it's just one extra cable.
    I spent ages (mainly on marine forums) working out the best way of doing this in a motorhome. If interested this is my whole charging system:
    [​IMG]
    (although no Smartcom now as I went with a compressor fridge)
    • Like Like x 6
  12. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,175
    12,520
    goole
  13. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Lost in La Mancha, Spain
  14. WOOOODENTOP
    WOOOODENTOP Funster
    Apr 19, 2014
    79
    44
    CHESHIRE
    Fit a solar panel
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    The simple answer is yes, he's talking bollox.
    Many folks have 3 or even 4 batteries connected together as one and they charge ok.
  16. Yorick
    Yorick Funster
    Oct 1, 2013
    3,998
    5,874
    Lanzarote
    Yes. I'm gonna fit one. But still would like answers to this please.
  17. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,960
    2,785
    Kendal, Cumbria
    Absolutely correct. Alternator size is irrelevant and it will perform exactly as JJ says.
  18. Chris
    Chris Funster Life Member
    May 5, 2010
    16,561
    35,215
    kent
    Thanks.
    I think I might have a crack at that at the weekend.
    Looks easy peasy to a man of my abilities.
    Anyone got any idea of the value of a 2013 burnt out Autotrail Scout?
    • Like Like x 2
  19. TheCaller
    TheCaller Funster
    Sep 23, 2013
    1,870
    2,240
    Lincs
    I don't think you can better this for a bare van conversion. The only thing I would do differently would be to feed at least one fuse box from the 12V 80A voltage regulated Consumer output on the SMARTPASS, rather than direct from the batteries. I would then put anything likely to suffer if supplied with the 14+V charging voltages on this fuse box. When in 'Recover' mode, the MXS 25 can be pushing out over 15V. This output also protects the batteries from over-discharge, because it shuts off if the batteries drop to critical levels.
    I can't find the exact voltage that the Consumer output is regulated at, but I suspect it is limited to 13.5V max, because that's what CTEK mains chargers provide when in 'power supply' mode.
  20. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    I'll give you a quid (delivered)
    • Like Like x 1
