Seat Plastic (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
I have fitted a safe under the Passenger seat so this part is spare, Ducato 2003 free to first person just pay the postage at cost.
Aug 13, 2009
49
22
KENT
Caravanning since 1990's Went over to motorhoming 2007
Hi Paul Can I ask you what make of safe you fitted as I'm hoping to do this too?
Kev
pvw10
pvw10
273
45
Gloucester
Coach built
Kev
Hi Kev,
sure you can, i will also post some pics so you can see the mod i had to do.
pvw10
pvw10
273
45
Gloucester
Coach built
Kev,
pictures as promised showing both model and hacking i had to do to get a perfect fit. Its a great safe nice and deep and totally invisible until you get very close to it.
Anything else just shout,
Scout
3,958
120,888
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
wont you want the bits to put back later if you sell the van on? even if you leave the safew in situ new owners might want the bits?
why not use velco to use them to cover the safe front?
belt/braces
pvw10
pvw10
273
45
Gloucester
Coach built
belt/braces
Hi, thats a good shout but its only the front cover, the rear is still on.The safe is so strong where it is its part of the chassis now so wouldnt like to remove it, mega job the way i fitted it he he
It goes with the mh.
Aug 13, 2009
49
22
KENT
Kev,
Thanks Paul....your info should save me a few hours of trying to work things out! :thumb:
TheBig1
17,592
43,009
now just paint it black and it would virtually disappear
Scout
3,958
120,888
South Yorkshire
chic c line
as JJ might say "just like that" or was that somebody else:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Kev,
How is it fixed in place Paul?
pvw10
pvw10
273
45
Gloucester
Coach built
I needed to be cunning to out do any scum that might find it so..........
Take the seat out after carefully marking where it would sit and checking no underbody pipes/hoses etc. Then drill down from the top two say 12mm ish holes and the same through the safe floor.
Then pass two 12mm bolts up from outside into the safe so the threads are visible and cut them down to as short as possible but allowing for two nuts. Then tighten the first nut tight then lock the second nut against the first so if they try to undue from underneath they have no chance. Even trying to undue from the inside its impossible as its a two man two spanner job.
If you see my photo i did all that but mis measured a bit so thought easier to cut the safe down a little. Space is tight and the safe door just opens so check check and check again but is a right pro job even though i say so myself.
If more pictures are needed just ask away.
