Scratched/scuffed plastic windows. Result (1 Viewer)
Feb 27, 2011
14,732
75,880
UK
Self Build
I had a large area of one of my plastic windows which was badly scuffed to the point where you couldn't see through that area.
I have just bought a load of different buffers, polishers, waxes, creams and pastes off Amazon and have set about testing them today.
The end result is a window I can see through and with a bit more elbow grease I am confident I can bring back to as good as new.
The winner in this little competition was something I have never heard of called Peek.
http://www.amazon.co.uk/gp/product/B000TRQFGM/?tag=mhf04-21
This stuff worked a treat on my windows and it is only £2.48 for a small tube.
As with anything though your results may be different from mine so try at your own risk.. But I am seriously impressed with the results I got.
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
By hand. It has taken out all but the deepest scratches. I am going to get some wet and dry on it to get rid of the scratches then redo it with the Peek.
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
I see its 'By appointment to Her Maj' , if its good enough for the Crown Jewels its good enough for me:LOL:, thanks for review Grommet(y)
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
Just tested it on my chrome kettle and thetford toilet and it worked a treat on both. I will be buying a big tin of it next order...
3
34127
Once saw a clip on you tube, someone polishing some headlamps that had gone yellow and he was using toothpaste, and it worked.
FJmike
972
1,046
Swindon
over ten years
I always use Meguiars PlastX when polishing acrylic windows on my valets, not as cheap as Gromett's Peek but have probably used it on hundreds of acrylic windows and I'm always pleased with the results ( as well as my customers). A couple of pointers when polishing acrylic windows, no matter what compound you use, if you can feel the scratch with your finger nail it isn't going to polish out completely, also if your using a machine polisher, don't use too much pressure and keep it moving all the time. Most acrylic windows fitted to motorhomes have a coating on them ( hense fingernail test) if you go through this the window will appear patchy, for which only replacement is a cure.:eek::eek:
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
I tried toothpaste, brasso and duraglit already. None of them worked in fact some made it worse.
The Peek worked really quickly with very little elbow grease.
FJmike
972
1,046
Swindon
over ten years
Borderland I'm told Brasso works as well but I'm not that brave. Headlamps are a different kettle of fish to acrylic windows
mikebeaches
5,393
8,597
Bristol
Rapido V68 Van Conversion
Since 2009
Thanks Gromett - have just ordered some on the basis of your review and the bargain price on Amazon!
Much appreciated.
Mike
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
Much appreciated.
Mike
Test it on an area that is not immediately visible before going full bore on it. I don't want you to hold me responsible if it doesn't work as well for you:eek:
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
I am off down to get the wet and dry tomorrow. Once I have used it to remove the deeper scratches I will attempt to take pictures before and after using the peek on the scuffed up area. Might be hard to get pictures though but will try.
3
34127
Likewise, I would rather use a known product for the job in hand
Oct 27, 2013
712
11,082
Portglenone, Northern Ireland.
Elddis Magnum185GT
Since July 2012
I had a coming together with an unseen sticky out branch some time ago, put a couple of scratches all down the van, including two windows. Went over the marks gently with T-cut and it worked a treat. The only (slight) marks left are on the decals.
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
I tried t cut as well. it took a bit out of the damage but still left the windows hazy to the point of being unusable.
I perhaps should have said what I had already tried in my original post...
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Here is evidence of the effectiveness of Autoglym
BEFORE
AFTER
Jul 23, 2013
381
221
Scotland
knaus van ti 600mg
Getting There since 2013
I did use brasso on my window was a bit scary at first especially as the window went completely hazy but a bit of elbow grease and it worked a treat :) mine was just light scratches so you'd have to make your own judgement whether to use brasso!
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
Just went into town to get a load of shopping in and the indoor market in Louth is selling Peek at £1.99 a tube so I stocked up (y)
FJmike
972
1,046
Swindon
over ten years
Gromett before you get out the wet & dry please read my post about deep scratches.
Gromett
Feb 27, 2011
14,732
75,880
UK
Self Build
I read it. The window is beyond that stage already. I can't make it any worse.
Badknee
7,407
412,582
notloB
Vantage Neo
Living the dream.
We used to clean the headlights on my lads Matiz for its MOT. Less abrasive wet and dry and end up on I think 1800's with a lot of washing up liquid to make the paper 'slide' then finish off with T cut, worked a treat.
FJmike
972
1,046
Swindon
over ten years
Having worked in a car garage I have brought loads of headlights back from a murky finish to sparklingly clear, but the plastic is completely different to that used in motorhomes
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Yorkshire Trading or one of the little stalls around the cafe? I'm walking past in the morning (dentist appointment), will drop in & get some - I've a scratch on one of mine too.
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
I can also vouch for Peek, friend of mine gave me a tin, he used to use it on his motorcyle helmet visors and swears by it. I've tried it on my windows and very happy with the results. :)
Main thing is to keep it wet with a bit of water whilst doing the main elbow work so as not to create too much heat but thats probably more important to watch out for when using an electric polisher.
