scooter/m-bike
Discussion in 'Motorhome Chat' started by darklord, Feb 28, 2012.
  1. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
    Seeing i have the "A" on my license, that allows me to ride a (cant remember) BHP machine, i am assuming carrying a passenger, are there some suggestions for what is good/bad etc.
    We only want it for bimbling about when we park the MH, and a bit of commuting (about ten miles a day), al, advice appreciated.
  2. motor roamin
    motor roamin Funster
    May 23, 2010
    1,535
    785
    Leicester
    If it is a full Cat A with no restriction code afterwards then you can ride any motorcycle/scooter you want with a pasenger.....If you have restriction codes (numbers) then I cannot remember what number is which restriction.
    Hope this helps a bit
    All the best Rick
  3. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,723
    23,133
    Narrfoook
    As Rick says...
    This from the latest DVLA updating mails:
    P Mopeds with an engine size of up to 50 cc and a maximum speed of up to 50 km/h
    16
    A1 Light motorcycles with an engine size of up to 125 cc and a power output of up to 11 kW (14.6 bhp)
    17
    A Medium-sized motorcycles up to 25 kW (33 bhp) and a power to weight ratio of up to 0.16 kW/kg
    17
    A Motorcycles with a sidecar and a power to weight ratio of up to 0.16 kW/kg
    17
    A Any size motorcycle, with or without a sidecar if you have completed the large motorcycle Direct Access Scheme
    21*
    *You can ride a large motorcycle at any age two years after passing a test on a medium-sized motorcycle.
    As to what.. Two up, ten miles.. I would suggest a minimum of a 250cc
    A few reasons.. Although a smaller bike will do the job it will struggle if you encounter any sizable hills
    Be uncomfortably slow on major roads and have difficulty keeping up with faster moving traffic ( can be even more dangerous than going too fast ! )
    And the best one of all.............
    125's are much sort after.. They retain a very high resell value so you will end up paying through the nose for not a lot..
    A decent 250 ( even something like an old Honda 250 Dream ) will likely not have had too hard a life, is cheap to run, easy to get spares for, and will cost very little ( compaired to other options ) in initial outlay
    If you have not ridden a bike for many years, a 250 should not get you in too much trouble either as chances are it will have only about 20 BH to play with
    • Like it Like it x 1
  4. darklord
    Apr 28, 2011
    1,241
    1,243
    essex
    Just checked the license, and it is "A" with no codes or anything else. So am I right in assuming that it is up to 33bhp with a passenger?.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    a full A licence without codes is unrestricted.......ride what the hell you like. :thumb:
    21*
    Jaws list is the current list for new-ish riders.......
    you must have taken a bike test years ago and it doesnt apply.
    took mine back in July 1975
  6. Jaws
    Sep 26, 2008
    18,723
    23,133
    Narrfoook
    As PJ says :thumb:
    Wanna buy a Blackbird then ?? :Wink:
