Schaudt EBL220, DT220 and LR1218
Discussion in 'Solar Power' started by dally, Apr 7, 2016.
  1. dally
    dally Funster
    Aug 12, 2012
    35
    54
    SOUTH LAKES
    Today I have fitted a solar panel to our Burstner I685. It's wired into a Schaudt LR1218 solar regulator then into a Schaudt EBL220 electroblok which is controlled by a Schaudt DT220 control panel.
    I know I have power going into and out of the regulator and also as far as the 15amp fuse on the electroblok so I'm assuming all is good. The problem I have is that the control panel is showing nothing regarding the installation and it's supposed to.
    I have done a bit of research and it would appear I need to enable "the solar current" on the DT220 control panel which includes a pin number. I have no idea how to do this but I have done a search on here and there is a lot written about Schaudt products so I was hoping someone has already done this. Any thoughts folks?
    cheers
    Stewart
  2. kaasbroodje
    kaasbroodje Funster
    Sep 14, 2013
    722
    784
    Bristol
    I don't have the exact links to hand (using different computer) but if you Google 'Schaudt dt220 code' you'll find all the answers you need.
    I can't remember the exact sequence, so won't attempt to explain it, I can say that it's only a five minute job (y)
    *edit* Hymer code is 8251, might work for you...
    • Like Like x 2
    • Informative Informative x 1
  3. bigtree
    bigtree Funster
    Oct 15, 2011
    543
    995
    Glasgow
    I believe each manufacturer has a different access code for the control,think mine is 1851 (Frankia) but as said once accessed it is a 5 minute job. Try emailing Udo Lang at Schaudt,I found him very helpful.
    Udo.Lang@schaudt-gmbh.de
    Just did a google search and found 2291 for a burstner 747
    • Like Like x 2
  4. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    309
    288
    Leeds
    I have a Dethleffs and these are the instructions:
    Dt220 pin is 4520
    While system is switched off (12 V off) press the buttons MENU and OK for at least five
    seconds to enter the set-up menu.
    The code number request appears (PIN: xxxx).
    Press the OK button and the first digit flashes. Set the first code number by pressing the +
    or – buttons, confirm by pressing OK, the second digit flashes, etc …
    After confirming the forth code number by pressing the OK button, the first symbol of the
    options which can be activated or deactivated appears flashing.
    The flashing symbol can be selected on or off by pressing the + or – buttons (or
    2ON/3ON/OFF with the Duo-/Triomatic gas pressure regulator system). Press the OK
    button to confirm. The symbol stops flashing and by pressing the MENUE button the next
    option can be selected.
    To exit the set-up menu, press the 12V-button or simply wait for 30 seconds.
    *Display of solar current is parameter number 4*
    Regards David.
    • Like Like x 1
  5. Cavs
    Cavs Funster
    Apr 10, 2010
    245
    245
    Bedfordshire
    I've just had the same done to my Frankia with the same Electrblock, etc. albeit using an LRM1218 regulator. I can see that the solar panels are charging by looking at the control panel voltage and current. As I understand it, delving into the menu system with a PIN is only required if you want the little solar icon to show on the panel. I have not done this (don't know the PIN) but the solar is obviously working.
    I got all necessary manuals and instruction books (in English) from Udo Lang, but he said I needed to get the PIN from my dealer.
    • Like Like x 1
  6. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,042
    2,915
    Essex
    8251 for my hymer. Can see in out for my solar on panel.
    Brownhills wouldn't give me code. Wanted me to travel 120 miles each way, but Google was my friend lol
    • Like Like x 1
  7. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,057
    484
    What is the battery voltage showing?
  8. dally
    dally Funster
    Aug 12, 2012
    35
    54
    SOUTH LAKES
    I was on EHU at the time so batteries were showing vehicle battery 13.3v and habitation at 13.6v. I did remove from the mains to check but I could do with looking now for a comparison. Unfortunately, it's my first day back at work so I can't compare it till Tuesday.
  9. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,057
    484
    I have a Schaudt LR1218 and a Schaudt IT991 control panel. If the batteries are fully charged nothing shows on the amp display even in full sun, but pressing the battery meter show around 14.0v so I know panels are putting a trickle charge in.
  10. Whitebirdyman
    Whitebirdyman Funster
    Oct 8, 2009
    131
    63
    Kent
    SMC were very helpful and gave me my Frankia code for a EBL220 and a DT 220 B, it is 6181. I had also queried this direct with Frankia, they were initially reluctant to give it to me, but after a bit of discussion they did give me the code, the same one that SMC had given me. They did warn me to be careful with it though!
    • Thanks Thanks x 1
  11. dally
    dally Funster
    Aug 12, 2012
    35
    54
    SOUTH LAKES
    I emailed Schaudt. Got a prompt response but they say that they can't give the code out. (Not bothered because I now have it ) thanks to bigtree.
  12. Cavs
    Cavs Funster
    Apr 10, 2010
    245
    245
    Bedfordshire
    I've just reprogrammed my DT220. Thanks to Whitebirdyman - the code for mine was 6181 as well. Enabling the solar icon also enabled an additional couple of entries in the menu. Cycling through the battery button sequence now additionally shows the solar charge going into the leisure batteries and (separately) the starter battery.
  13. Chipster
    Chipster Funster Life Member
    Oct 15, 2013
    396
    242
    East Midlands
    So does the standard LRM1218 4 pin display cable plug directly into the Frankia panel?
  14. Cavs
    Cavs Funster
    Apr 10, 2010
    245
    245
    Bedfordshire
    The four pin cable (with only two pins wired) that came with the LRM1218 joins a port on the regulator to the BL9 socket on the EBL 220 Electroblock. (I pulled the fuse on the solar input before doing so (y)) Then go into the DT220 to do the reprogramming.
  15. Chipster
    Oct 15, 2013
    396
    242
    East Midlands
    Ahh. Of course. Thanks. The solar data is then transmitted down the original Frankia cable to the Frankia panel. Provided its enabled. Planning on doing the same.
  16. dally
    dally Funster
    Aug 12, 2012
    35
    54
    SOUTH LAKES
    Many thanks to dpsuk999 for the step by step guide. Followed it earlier today and got the icon turned on. 2 minutes it took. The Burstner code is 2291 so thanks to bigtree. Just got to reprogramme the KHV sat dome then I'm sorted
