Scary Stuff
Discussion in 'Tech/Mech General' started by Geo, Nov 26, 2014.
  1. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,864
    6,114
    Mansfield,Notts
    Horror-story-Something-missing.jpg At fist glance it looks like the Garage or fitter forgot to put the nut on
    this was spotted at an MoT test so all was well
    However a similar incident resulted in an accident where by the police and accident investigators were involved, at the scene a few meters away the nut was found split into two halves!!
    So maybe this nut was fitted also, who knows? only the fitter and his God,
    He will have a hell of a job proving he did, I know he would never convince anyone here
    Is it cheap Chinese e bay parts :eek:
    G
    • Like it Like it x 1
  2. trophychap
    trophychap Funster
    Dec 24, 2009
    736
    6,225
    bedworth warks
    Well Geo looking at the picture it appears to me that a cotter pin is in place. I wouldn't think anyone would go to the trouble of putting in a cotter pin if they had not replaced the nut do you? It also looks as if the face of the ball joint around the area where the bolt comes through is not showing any corrosion that to me indicates it was covered up I favour the nut split and disappeared myself.
  3. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Absolutely correct. A high tensile castellated nut is required at fitments such as steering swivels. To fit mild steel is not good enough. My money is on a mild steel nut having been fitted in the past, and not necessarily by the last fitter to take it apart.
    Is the photo of the top link, or the bottom??
  4. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    It may not have been the wrong type of nut. Castellated nuts have been known to split when a crack starts at the base of one of the castellation cuts.
  5. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    Agreed, but a process far less likely to occur if the nut is high-tensile. :)
  6. Ranger
    Ranger Funster
    Nov 2, 2008
    246
    204
    Lincolnshire
    Blimey not seen that before I wonder if it was the old nut refitted or a dodgy new one. Couldn't be much worse than a bottom ball joint. I for one will be checking my nuts more carefully in future.
  7. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,347
    1,701
    Dover
    Not so the not is not the tensile item the bolt is, they are normally the same material anyway but they do crack through especially if overtightened to get the hole lined up. Most metric bolts are 8.8 or higher unless you go to B&Q for carrot steel.
