Satnav mount
Discussion in 'Motorhome Chat' started by motorhomewave, Apr 14, 2016.
  1. motorhomewave
    motorhomewave Read Only Funster
    Jul 17, 2009
    138
    51
    Picking up new MH next week after seven years with a very reliable and much loved 6m model and moving up to 7m (not the point of this thread) ! Things have progressed in 7 years and the old CD/radio has been replaced by a digital, bluetooth, mp3 player, just one problem with that...the sat nav used to fit snugly into the slot of the CD player by means of a cleverly designed plate, easily removed and put away when not in use. but of course no longer there. I'm not keen on sticking the sucker on the windscreen all those round marks left everywhere, anybody know of any other clever fixings you can use on a Peugeot Boxer base ?
  2. Pikeman
    Pikeman Funster
    Nov 6, 2011
    292
    323
    Worthing
    You could go for the weighted dash board mount, but it needs to be relatively flat. Keith :cool:
    [​IMG]
  3. bertiebasset
    bertiebasset Funster
    Jun 16, 2014
    305
    291
    NOTTINGHAM
    • Thanks Thanks x 1
  4. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,822
    3,132
    Manchester
  5. The Dude
    The Dude Funster
    Jan 10, 2013
    2,580
    2,572
    Near Uttoxeter and Crete
    We have an A class so when the satnav is stuck to the window I can't see it or reach it. We use one of the sticky disks now similar to this, and it is very stable.
  6. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,897
    8,994
    NW England
    I turned our old TomTom's window mount upside down and screwed the suction cup to top of the dashboard. Still worked.
  7. mikebeaches
    mikebeaches Funster
    Feb 22, 2010
    1,217
    830
    Bristol
    • Like it Like it x 1
  8. motorhomewave
    Jul 17, 2009
    138
    51
    A multitude of ideas, thanks all, I shall trawl flabby, the pad idea sounds good !
  9. scotjimland
    Jul 25, 2007
    28,994
    25,691
    Suffolk
    If I put mine on the windscreen I'd need bino's to read it..
    Have it stuck to the drivers quarter light side window.. can see it easily and can also use it , change route etc. while driving ;)
  10. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,744
    2,693
    Cornwall
  11. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    I mount ours on a tub pushed into the cup holder. Photos Here.
    • Like it Like it x 3
  12. iandsm
    iandsm Funster
    Jan 3, 2008
    1,705
    2,844
    Suffolk
    Try http://www.dsldevelopments.com you can get a mount especially for you vehicle. Ours if just on the top of the air vent to the left of the steering wheel and very reachable and visible. You need the vehicle blunt and then the part for the satnav which will then attach to it.
  13. Badknee
    Badknee Funster
    Aug 25, 2014
    3,840
    17,234
    notloB
    I've just mounted ours to the roof lining next to the interior light after first reinforcing the headlining. It's a 7inch Chinese truck one that is now tucked up out of the way, close enough to see and out of the sun so no reflection in it. Reinforce the lining and two self tappers through the suction cup normally stuck to the screen.
  14. Bernie P
    Bernie P Funster
    Mar 18, 2015
    78
    67
    Guildford, Surrey
    If you have the "papers" clip like the Ducato version make strip of thin ply screw the satnav mount base to that, stick a bit of dense foam over the bolt heads to compensate for the curve of the dash. one clip in sat nav stand that don't move.
    When it stops raining I'll wander out to the MH and take a picture.
  15. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,593
    2,785
    Surrey
    That's what we use, I have it stuck to the dash on the right hand side of the steering wheel. Makes life easy for using the screen being that I am right handed! :D
  16. motorhomewave
    Jul 17, 2009
    138
    51
    Thanks all ! some great ideas. I have gone for the mat option from eBay, seems the simplest, if it fails to work the paper clip option might be the way to go, will let you know. Going to France 1 day after picking up new MH so time is not on our side !
  17. pollensabob
    pollensabob Funster
    Jan 30, 2008
    142
    92
    West Sussex
    I have a Brodit sat nav mount in motorhome brilliant they cover all makes
    Of vehicle
    Bob
  18. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,987
    1,739
    Bungay Suffolk
    We use an I-Pad with TomTom on it downloaded from' I-tunes' and also Campercontact.
    They work superbly together and it stands on the dash in its case. Dead easy to see and Jenny can see and update as we go along.
    Mitch.
  19. Poohbear
    Poohbear Funster
    May 18, 2015
    281
    457
    Worcester
    Does yours not have one of these like the FIAT does: - [​IMG]
  20. motorhomewave
    Jul 17, 2009
    138
    51
    Not sure, haven't got the vehicle yet, would be good if it had, just stick it on the plastic thing. The old MH had a pull up plastic leaf for clipping papers to, not sure it was as big as that, never opened it !
