SATELLITE SYSTEM for my rv
Discussion in 'Motorhome Chat' started by do1977, Jun 3, 2009.
  1. do1977
    do1977 Read Only Funster
    Oct 28, 2008
    86
    where i park up
    i ant to get a B2590 MAXVIEW SATELLITE SYSTEM WITH ELLIPTICAL DISH for my rv has any one got one of theseor used one
    are they realy that esey to use and work well and they say??
    or shuld i go for sme thing eles?
  2. Lampie
    Lampie Read Only Funster
    Nov 2, 2007
    169
    Derby
    I have the Maxiview crank up on my RV and works fine, quite easy to fit if your doing it , simple to use. Worked ok South France and Lake Garda the last few years.
    Regards
    Lampie
  3. do1977
    Oct 28, 2008
    86
    where i park up
    ok thanks for that i have been offered one for £250
  4. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    Hi I too have a crank up Satallite dish straight forward to fit, however I had to get a longer spindle and small box section connecting the crank to the dish mechanism due to the thickness of my roof.
    [​IMG]
    Regards Pat
  5. do1977
    Oct 28, 2008
    86
    where i park up
    ok i have a thick roof on my winni so i will have to do the same as youwhere did you get the extrs bits from?
  6. ruffingitsmoothly
    Jan 2, 2008
    1,395
    69
    Hi managed to get the box section from a local metalwork company but had to buy the length of square drive bar from 'Machine Mart' or 'B&Q' I think, then weld a short piece to the original.
    Regards Pat
  7. do1977
    Oct 28, 2008
    86
    where i park up
    ok thanks for that
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    I also have a Maxview crank up but wouldn't recommend due to problems with it moving in the wind.
    [​IMG]
    Full story here:
    http://www.motorhomefun.co.uk/tv-satellite/2606-maxview-crank-up-not-so-good-wind.html
    Have a look at the CAMOS CRANK-UP "FLAT-SAT" SATELLITE DISH (RPR-D2259)
    CAMOS CRANK-UP ??PLUS?? SATELLITE DISH from RoadPro
    Report from owners
    http://www.motorhomefun.co.uk/tv-satellite/10941-camos-crank-up-satellite-dish.html
    There are others who do Through-Roof Systems
    Alden Confort, Globesat, Kathrein BAS.
  9. olley
    olley Funster
    Jul 29, 2007
    3,746
    2,189
    Ipswich
    Hi I also have a maxview, and unlike Jim have never had any problems with it, but we don't have it up in strong winds.
    Ours is also a winnie and if your roof is the same as ours (glassfiber) the spindle and box section supplied with the maxwell are all long enough.
    Olley
  10. scotjimland
    Jul 25, 2007
    28,936
    25,589
    I had no problem with the shaft and spindle length ..
    After complaining about it moving Maxview visited me and fitted a new cranking mechanism, but as luck would have it there was hardly a breeze that day.. :RollEyes:
    I have said repeatedly that it does perform well, is easy to align and works all over Europe but it suffers from a poor braking system that will blow it off line when it's gusty ..
    When in Mimizan last Feb we couldn't watch TV for several days , yes it was windy, gusting around 25 - 30 kts but other vans with Alden and Camos weren't affected ..
    hence my advice.. it is given without prejudice, I have no other motive other than to tell as I find.
    If you don't mind cranking down in poor weather .. it's great, paradoxically it's in this kind of weather you are more likely to want to watch TV :Doh:
  11. jacken
    jacken Read Only Funster
    Dec 9, 2007
    190
    kent
    I have a Oyster dish on my roof and travelling down through France, into Spain and then Portugal--I have found that the vans with dishes on the roof have more trouble getting a signal than the people who have a free standing dish. The biggest problem is trees or anything else in the way. It is not always easy to move the van to a better spot when on a pitch, then you have the wind. I got so fed up when in Portugal that I went out and bought a free standing dish and can now set it up with a good signal in a few minutes. I personally would not have a dish fitted on the roof again, knowing what I know now.
    ken
  12. stagman
    stagman Deleted User
    I have fitted the Maxview to 2 of my vans .Both easy to fit and worked very well down to the South of France.Easy to set up .If it's windy use your head ,can you be without for one night .One evening near La Rochelle a couple years ago pulled up in an Aire and decided it was too windy to use the dish so I didn't . A van pulls in with something like a £1,500 automatic dish and the wind destroyed it ,so:thumb:
  13. Bugsy
    Bugsy Read Only Funster
    Oct 25, 2008
    62
    Norfolk
    We've just fitted the Maxview B2590twin LNB version to our RV, because we wanted to use our Sky+ digibox. We also had to get the longer spindle and shaft and as Maxview are only 40 miles from our home (near King's Lynn, Norfolk,) Barry went over and collected them.
    We had a lot of problems fitting it because you have to be precise to the mm when you cut the spindle and shaft!!!! In the end Barry got so frustrated because he could not get the spindle to fit, that he took the RV over to Maxview and saw their 'techie.' It took him 1 1/2 hours to get it working and he knows what he's doing and he also cheated by removing the lugs off the one of the pieces which fit on the inside of the vehicle. This allowed him to measure without permanently fixing the unit, not something you can do yourself. It would seem that Barry cut the shaft 1mm to long, which prevented the spindle reaching the dish mechanism and he explained to the 'techie' that he thought that the tolerances were far too precise for someone trying to fit this at home.
    You also need to be careful when measuring where you wish to fit the dish so that it does not touch any other equipment.
    We purchased our dish from GVL. www.guardianeu.com and you can also purchase the system from Snellyvision, ************************* Both companies will fit the system for you for a fee of £150.00 but obviously it all depends on where you live as to whether or not this is a cost effective option.
    Anyway, it's up and running and working nicely. We use the system set up/signal strength menu on Sky when tuning in and so far it's been brilliant. We even had it working when it was quite blustery without losing the signal.
    Good luck:thumb:
    Toni
