Satellite not working ? (1 Viewer)
Jul 3, 2012
136
106
Essex
Bought motor home two yrs ago after having caravans for 30 years
Hi were at Malvern has anyone got any ideas why we can't get our oyster unit to pick up , it's only two yrs old , it says LMB failure , it searches for Astra two but don't find it , the man on trade stall wants £50 to look at it , any help would be appreciated were on disabled field thank you
sean n maggie
672
327
leeds
autotrail
check connections in to sat box,,if those ok then sure one of funsters will nip up on roof to check connections to lmb at dish ok....sometimes turning off and re seting does the trick....and is it finding the sat ?
TheBig1
17,592
43,007
LNBs do fail, as do cables and connections corrode. the easiest way to double check is run a temporary coax from the sat box to the LNB
otherwise you will need to get a replacement LNB from Oyster or have somebody fit one for you
Dec 6, 2011
11,554
25,336
South Wales
Coach built Adria
Hi. if it says LNB failure then either the LNB is faulty or the power supply to it so as already mentioned above check the connections at the Digi box are secure. then its up on roof to check the connection to the LNB. if all the correct connections are in place and there is voltage to the LNB then it is likely a new LNB is needed.
i am assuming that the dish does raise and turns to search.
Pamee
Jul 3, 2012
136
106
Essex
No it's not finding the sat
Pamee
Jul 3, 2012
136
106
Essex
Ok thank you
Pamee
Jul 3, 2012
136
106
Essex
It's looks like a new LNB then , I'll go over to trade stalls and get the fella to fit one thanks all for your help
tonka
10,823
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
I suspect just a badly fitting "F" plug...
The Inner and outer cables often slide and can cause a short or poor connection, having it on a mobile vehicle and a turning dish gives it all the more chance...
Glad you got it sorted and also at a sensible price."
Pamee
Jul 3, 2012
136
106
Essex
It was the transponder code it just needed reprogramming x
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
You're correct in principal but the OP trumped you with their answer
