satellite not locking on
Discussion in 'Motorhome Chat' started by driving, Jun 4, 2012.
  1. driving
    driving Funster
    Mar 7, 2012
    97
    99
    doncaster southyorkshire
    can anybody help I have a glomex satellite system and it will not lock onto astra 2 does anybody know of a dealer or a service department for them that are based in the uk as they are an italian company thanks
    mark
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,610
    22,758
    Narrfoook
    Any idea when it was last used successfully ?
    If it was last year, then I am afraid you will need to either replace the controller or MAYBE you can get it reprogrammed
    Sometime early last year the channel almost all the automatic systems was turned off on the satellites ( It was a BBC channel )
  3. driving
    driving Funster
    Mar 7, 2012
    97
    99
    the system has only been fitted 10 weeks ago and it was used last week
    thanks
  4. AndrewandShirley
    AndrewandShirley Read Only Funster
    Jun 3, 2012
    4
    Europe
    We have the same problem atm with our Glomax.
    We can lock onto Astra 1 and Hotbird but not Astra 2.
    Planning to move the van tomorrow and try elsewhere on the site.
  5. driving
    driving Funster
    Mar 7, 2012
    97
    99
    we have already tried this even outside my house. ours locks on to astra1 and hotbird too. do you know of a service department for glomex in the uk
  6. Jaws
    Sep 26, 2008
    18,610
    22,758
    Narrfoook
    I believe the Glomex uses a fairly standard control box.. I would suggest contacting Robert Jackson .. Him and his son are extremely helpful and very knowledgeable
    If your controller can be reprogrammed, they will know !
    http://www.jacksonsuk.com/
    • Like Like x 1
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,737
    5,967
    Mansfield,Notts
    I have posted this before but worth a second viewing
    Sat systems use computer logic and if it already knew where astra two was and you ask it to look again it may well work out,the fact that you have asked it to find it, it must not be where it thought it was and so wont look there ever again:RollEyes:
    Best solution is pull the plug and kill all power to it to erase all memory and allow to re boot and start search again
    May not work if you have a fault but it has cured quite a few that thought they had a fault
    • Like Like x 2
  8. autoswan
    autoswan Funster
    Apr 3, 2012
    654
    1,598
    Swansea
    sorry to but in but thought id save a new post on similar subject im on a site near pembroke and cant get a signal on my free view tv the flying saucer shaped dish/ariel on the roof has a status power pack in cab but nowt happening it works at home but had same prob easter near Tenby too.
    I even tried an arial we use at home with 2 pull out arms and with a plug in booster though its an indoor type
    Is there something i can do/try to make it pick up a signal others here have similar arials as well as some nasa looking dishes etc.
    if no go then it looks like a big nasa type dish set up will be needed but why would manufacturers fit a crapy flying saucer type arial with status power pack if it cant pick up nowt when not in sight of a mast .
    Only concerned because swmbo and young un want thier progs if as expected rain comes and we spend a bit of time in MH and i miss family guy !:BigGrin::thumb:
    • Like Like x 1
  9. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    The Status "omni-directional" (flying saucer) aerial should be called the "Oh-My-No-Direction-At-All-Aerial" unless you are very close to a transmitter. I have a directional Status antenna on my current van with the Status "booster" but that is also not so brill. Sometimes I get a stronger signal/picture just by putting my finger directly onto the TV antenna socket rather than plugging in the "Status"....
    Sat TV is the way to go. Especially now with digital TV it's "ALL OR NOTHING" especially on terrestial.....
    For years I have used a normal sky dish (small 60cm "NASA" dish) on a tripod with a flex in through the skylight, total cost £35. Perfect picture from the north of Scotland to the south of France. Average set up time, 5 minutes.
    Now I have an automatic sat dome just so I don't need to go out in the wet to set the sat TV setup. But for £35 you can get a picture anywhere...........
    • Like Like x 1
  10. autoswan
    autoswan Funster
    Apr 3, 2012
    654
    1,598
    Swansea
    Thanks Callumwa that makes sense :thumb:
    Imist a dish deal in Aldis the other week anywhere else for a reasonably priced new one ? and how much roughly to replace the toy one on roof for a decent fixed type ? thanks :Smile:
  11. Geo
    Jul 29, 2007
    9,737
    5,967
    Mansfield,Notts
    Do some research and shop around for one of these
    Buy once buy right
    Good = no cheap
    Cheap = no good
    stand buy for dozens of alternative suggestions
    Geo
    • Like Like x 1
  12. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    • Like Like x 1
  13. callumwa
    Jan 16, 2011
    4,113
    4,518
    Many people use the sets from Aldi Lidl etc, and they work fine, sometimes you can get them for £40 or £50 including the dish and the 12V receiver, great value. As I mentioned I used to use a sky dish on a tripod outside the van with an old sky box for years, I got a picture everywhere without fail.:thumb:
    Now I have one of these domes, the dish and controller cost just over a grand.
    [​IMG]
    It was fitted by Dave Newell.
    I have a Freesat 12V High Definition receiver like this, very small, very light, super HD picture for £60. You can also record to a USB stick.
    [​IMG]
    Takes an average 45 seconds to get a signal and be up and running.:thumb::thumb:
    • Like Like x 1
