Satellite Dish install
Discussion in 'Motorhome Accessories' started by ShiftZZ, Jun 9, 2013.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Are they simply glued on the roof?
    Just seen some instructions and that's what appears to happen..
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,285
    16,956
    Liverpool.
    Having taken an old analogue Oyster off a van some time ago I can only comment on the fitting of that one. There was a sheet of alloy checkerplate stuck to the roof with Sikaflex and the Oyster was then bolted to it. The glue was so strong on the stuck down bit, I had to leave it there.
    • Like it Like it x 1
  3. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Yes..in most cases... On mine I have just put sikaflex to the underside of the base plate then bolted the dish to the plate....NO screws....although there are holes in the base plate, but to be honest.. have you seen the thickness of the outside roof skin:Eeek: about 2mm thick..then the polystyrene sandwich the 4 screws would not realy hold anything......unless you intend to go all the way through to the inner 2mm ply inside and fit a large SS plate:Doh:
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    There is a plate stuck to the middle of the roof of our van with 4 studs protruding from it. When Dave Newell fitted our solar panel Jill asked if he knew what it was. He said it was most probably a base plate for a satellite system, similar to that referenced by Snowbird.
  5. icantremember
    icantremember Funster
    Sep 2, 2010
    5,390
    7,494
    Nr Watton in Norfolk
    Nooo ...... I'm sure in your case Graham it was one of these .........
    ...........[​IMG]
  6. GJH
    Aug 20, 2007
    27,349
    34,968
    It's years since we used a tent Brian :Laughing:
Similar Threads
  1. Nigel&Debbie
    20
    1,354
