Sat nav Garmin Nuvi playing up
Discussion in 'Motorhome Chat' started by Jac Sprat, Mar 22, 2016.
  1. Jac Sprat
    Jac Sprat Funster
    Feb 19, 2015
    1,012
    589
    Norfolk
    Don't know why but when we nearly reach our destination it cuts out and refuses to switch on properly. It's happened about 5times now! It's still quite new so it's very irritating. Has anyone else had this? It seems all set to drive to our next destination tomorrow but has a fit of the sulks if we ask it to go to the original now nearby place.
    We have a Kenwood Sat nav entertainment centre with a screen opening up above the radio. This came with the van. We switched it on once by mistake and it wasn't bad. We'd like to use it as a stand by for when Garmin plays silly buggers. We now can't switch it on! The select button is greyed out on the menu screen. We have spent ages looking at it and reading the manual but amazingly it doesn't tell you how to switch it on. .it's a Kenwood KVT -729DVD and is called a monitor with DVD receiver. Can anyone help? You can toggle between all the functions but sat nav doesn't come up!! GRRRRRRRRRRRRRRRRR!
  2. Scotties
    Scotties Funster Life Member
    Sep 23, 2008
    361
    167
    Norfolk
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,958
    12,241
    Plympton, Devon
    Is it possible your Garmin is becoming disconnected from the power and stops when the batteries run flat?
    The next time it happens check the plug is still properly inserted in the dashboard, they can vibrate out.
    • Informative Informative x 1
  4. Wickolad
    Wickolad Funster
    Sep 10, 2013
    482
    543
    Wickersley
    I have a Garmin nuvi in my car that suffered the same problem, cutting out and refusing to start back up, luckily I was able to reset it through the pin hole reset in the back. I hooked it up to the computer and went on Garmin web site, it was overdue a software update and since updating it, has never done it again.
    There's every chance yours is just in need of software update, even though it's not very old.
    Hope it solves problem for you. :)
    Lance
    • Like it Like it x 1
  5. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,711
    2,183
    Scotland
  6. Jac Sprat
    Jac Sprat Funster
    Feb 19, 2015
    1,012
    589
    Norfolk
    Thanks we are now on the road and didn't bring the Garmin- to -pc hook up lead with us as we'd just updated it. In retrospect a silly oversight. We won't be home for a month now.
    We did check the plug which was fine. Guess we'll have to wait now.
    Sorry no one has the same Goodwin system but I knew it was a long shot.
    Are there any good European ones does anyone know?
  7. John Laidler
    Jan 9, 2013
    8,958
    12,241
    Plympton, Devon
    Just a thought but does the Kenwood satnav only work with the engine running? I'm trying to think why the option to switch it on is greyed out.
  8. Larby
    Larby Funster
    Jun 17, 2012
    1,783
    4,083
    North Essex
    Could you set your destination say 5 miles further but put the required destination as a via?
    • Like it Like it x 2
  9. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,781
    4,246
    Newbury , West Berkshire
    Good idea ...@Larby
  10. Larby
    Larby Funster
    Jun 17, 2012
    1,783
    4,083
    North Essex
  11. Jill
    Jill Funster
    Jan 19, 2010
    162
    105
    Pembrokeshire
    Mine did that. We eventually trace the problem to the 12v plug unscrewing itself & losing contact internally. Sorted with a bit of locktight.
Similar Threads
  1. PeteH
    9
    334
  2. SUE L
    38
    1,224
  3. rosalan
    10
    468
  4. monaco/frankia
    47
    1,755
  5. Ovalball
    17
    619
