Sat dish from Maplins (1 Viewer)
Loujess
3,123
3,086
Leeds UK
none
Is there a thread on here about those satellite dishes you can get at Maplins? We just got one today and are going to try it out in the driveway over the weekend but it looks mighty complicated and sparks might fly. There is a cable which plugs the box into the 3 pin plughole, but what happens if you are on 12v. The 3 pin things don't work then. Or will there be something with the package that will help? I'm dreading this. :BigGrSatin:
Ivy
lesleyjean
1,748
2,392
Think positive Ivy:Smile:
Throw away the instructions:Smile::roflmto:
Spend hours trying to figure it out:Smile:
Search for instructions:Smile:
Give up:Smile:
Look at it another day:Smile:
Next time..........
Penny drops.......
Works a treat.....:Smile:
Good luck:roflmto:
lesleyjean
1,748
2,392
sorry Ivy:cry:
Someone will be along in a minute to help you.:Smile:
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
if you have got the suitcase set up meant for caravans/ mh etc it should have a 12v cig adapter with it . if it is the type meant for free to air at home it may well be 240v only ! garry
Sep 23, 2007
1,702
1,966
Leicestershire
4 and many as a tugger
Ivy
Hi if you look in the classified ads I am giving away a suitcase sat system complete but no reciever. If you can use this with what you have let me know.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Ivy
Many.
Usually ending in "The funeral will be tomorrow......"
First tip - look around, see where the other dishes point.
Second - give thanks to Allah.
Third - give thanks to Jesus.
Fouth - praise Buddha.
Fit the signal meter in line - you did buy one !
Note the dish does not point up, it's more or less vertical.
Make sure you have a clear line of site to satellite.
Now do a load of Z moves, side to side a bit, up, side to side a bit.
If you find a squeak on the meter but no picture you could be on the wrong satellite, move it just a few degrees and start again.
Open that bottle of Vodka you've kept for emergencies.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If it were a 12 volt version it wouldn't have a 3 pin thingy would it:Doh:
It would have the cig lighter lead and the same single pin socket with a 240v to 12v transformer
Me thinks with a 3 pin socket thingy your stuffed its mains 240v only:RollEyes:
43,207
48,802
not neccessarily Geo.
my old (very old) Comag Porty receiver (aldi i beleive but bought privately) has both 12v and 230v leads...permanently (factory) fitted.
no black box....its all inside the receiver.
230v on/off switch (button) on the front and a 12v on/off rocker switch on the back
Loujess
Loujess
3,123
3,086
Leeds UK
none
I think this is what we've got. It has got a cig connection but we have a U shaped lounge with the tv, obviously, at the back and it's a long way to the cig connection. However, I'm sure Maplins have an extension for that.
Link Removed
::bigsmile:
Ivy
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Ivy
Much better if you fit a permanent socket in the lounge then it's there for other things. And a touch safer.
You might need to search ebay for a sturdy old tripod to make mounting easier.
Loujess
Loujess
3,123
3,086
Leeds UK
none
Yes - I would have preferred a tripod but will the dish fit on any one or do I need a specific size/type? ::bigsmile:
Ivy
43,207
48,802
Ivy
mines clamped to an old camera tripod.
just needs a little ingenuity figuring out the clamping arrangement.
running an extension from the lounge to the cab may cause a volt drop.
as Brian said....a permanent socket near the tv would be better and easy to do if theres already a 12v socket for the tv.
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
Ditto.
Of course the problem with a low mounted tripod can be total lack of reception.
Loujess
Loujess
3,123
3,086
Leeds UK
none
We do have a 2 flat pin socket for the tv when we don't have EHU, but does this mean that we will still need another 12v socket in the same place for the sat box as well? I'm sure it will all become clearer on Sunday when we get cracking with it. ::bigsmile:
Ivy
43,207
48,802
Ditto.
certainly can be a reception problem when the dish is at ground level...so many things can block signals...houses, trees, walls, other motorhomes, TINFOIL. :Angry::winky: .
43,207
48,802
So now what you need is a caravan socket to cigarette socket adaptor. Does this look right ?
Link Removed
or possibly this type.
Brians image shows two angled flat pins...this one has two parallel flat pins, one slightly larger than the other so it only fits one way round.
TheBig1
17,509
42,755
for my tripod, I went for a more substantial one choosing a DJ type speaker stand. cost £25 at the time from maplins.
it hods the dish very solid and can be raised from 3ft to 6ft for sites that have problems with bushes and low trees. as a rule of thumb if a tree or other object is obscuring your direct view of the satellite you need to be at least twice the distance from the object as it is high.
oh and forget the awful little satellite dish in the kit. other than in the strongest signal band you will struggle to get a signal. certainly wont get a signal as far north as scotland or south in france. after struggling a couple of times to get and keep a signal, I bought a cheap 60cm house type dish. pick up a U bolt from a local exhaust fitter or ebay and a couple of wing nuts. couldnt be simpler
GJH
29,450
38,828
None, now sold
2006 to 2022
In our Autoquest the only 12v socket was that pattern. I bought one of those plugs and replaced the cigar lighter plug on a multi-socket adapter with it. I was then able to run both TV and (Aldi) Sat box from the one van socket (both very low power so no chance of overload).
