Sargent Ec500 Autotrail 2013
Discussion in 'Tech/Mech General' started by laurieash, Apr 26, 2015.
  1. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    339
    HALIFAX
    In my autotrail 2013 there is a Sargent 500 fitted, on the digital read out above the door the numbers just scrolling when charge going to the batteries.
    not all the time but more in the afternoon, does this mean the batteries are full from the sola panel?
    I have a 100w panel with one 110 Banner battery. But normal readout is 4.8
  2. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,189
    876
    Isle of Sheppy
    the amount taken from the solar panel will reduce to a maintenance charge when the batteries are full
    joe
    • Like Like x 1
  3. robnchris
    robnchris Funster
    Jan 11, 2010
    1,341
    1,616
    Chester
    Ours does the same and we have had it changed under warranty twice, for what ever reason the readings just go haywire, we have had a reading of 10amps discharge when nothing is being used, the freshwater showing 100% when it is bone dry empty and a solar power to batteries at 7.5 amps (we wish).
    Good luck with it, another fine selection of parts selected, fitted and tried out on the Guinea Pig customers.
  4. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    339
    HALIFAX
    Yes mine says full waste water when empty. I
    Just ignore that.
  5. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    339
    HALIFAX
    Is it worth getting it changed if it's still the same?
  6. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,462
    7,744
    Is this on just when the solar input is selected ??
    Mine flashes from a current to 0 and this usually indicates a full charge at the battery, the solar panel will still produce power but it's going nowhere. I have never seen anything I would describe as "scrolling"..
  7. robnchris
    robnchris Funster
    Jan 11, 2010
    1,341
    1,616
    Chester
    If it`s a warranty job then definitely, If not then you could try phoning Sargent, lots on here say they are very helpful.
  8. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    339
    HALIFAX
    [QUgoesTE="tonka, post: 1396183, member: 3141"]Is this on just when the solar input is selected ??
    Mine flashes from a current to 0 and this usually indicates a full charge at the battery, the solar panel will still produce power but it's going nowhere. I have never seen anything I would describe as "scrolling"..[/QUOTE]
    It goes from 0 to4.8 and back again over and over again in seconds
  9. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    339
    HALIFAX
    Yes when selected
  10. tonka
    Jul 2, 2008
    5,462
    7,744
    Sounds the same as mine... Had no issues and I have always put it down as being "normal" .... The battery is fully charged, once it depletes then a steady reading will return..
  11. laurieash
    laurieash Funster
    Jan 29, 2014
    575
    339
    HALIFAX
    Ok thanks for that tonka, can knock it of my list now
