Rv refurbishment seat belts etc
Discussion in 'American RV's' started by dundreamin, Aug 7, 2010.
  1. dundreamin
    dundreamin Read Only Funster
    Sep 24, 2007
    32
    South Yorks
    Hi,
    We ae refurbishing our Gulfstream by replacing seat covers, floors etc.In the course of this we have removed all the seats and seat belts. The rock and roll is easy enough to replace frayed belts with equivalent new lap belts to same mounting points but the driver and passenger seats are a complete new ball game.
    When manufactured they were just lap belts but we (me) would like three point belts to replace them. My difficulty is that there is nowhere on the chassis wall to fasten the shoulder height point to. You can put the reel on the floor but need another high point and we don't think that this wall on ours is strong enough.
    Has anyone solved this problem that could give us some advice.
    We had considered getting somesort of harness but we don't think these are suitable either.
    Any suggestion would be appreciated.
    Thank you
    Lynne:helpsos:
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,860
    6,111
    Mansfield,Notts
    Hi Lynne
    There are many out there looking for the same solution,mainly because front lap belt may not pass an MOT test on certain vehicles.
    Without a B post your all but stuffed
    A Racing type harness is the only real solution,short of contructing an internall B post welded through floor to chassis and supported best you can
    European Motor home builders have done this on some rear dinnett seats Swift as an example
    One or two have modified the seat back to take the mount
    I dont belive this method is strong enough
    If you use search buttons type in RV seat belts you should find all the old posts and replies
    Geo
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    No idea on the finer points of RVs - is it possible to fix the upper part of the seat belt to the seat back ????? would think being a yank tank they would be substantial ?
    well prepared to be shot down on this idea
    terry
  4. motor roamin
    motor roamin Funster
    May 23, 2010
    1,535
    785
    Leicester
    Hi dundreamin
    Be very careful when taking the seat belt mountings away from standard whilst it may pass an MOT, for insurance purposes I would have it designed by a Motor Engineer of at least Tech Eng level and make sure (unlike me) he still carries a valid insurance.
    If the vehicle was manufactured with lap belts and has been MOTed (it has been many years since I did MOT's but If memory serves, and it may not there is a cut off date as to when a lap belt is sufficient) in the past then as far as I know we havn't had any retrospective legislation in recent years to say it wont pass again. If you want to change them for safety reasons then that is different.
    VOSA will be able to give up to date answers.
  5. agilityeye
    agilityeye Read Only Funster
    Dec 8, 2009
    30
    Lancaster
    our rvision is 10 years old and has lap belts but it wont pass an MOT with them, so it has harnesses fitted now, b****y useless as you cant move in your seat if your going to use them correctly:RollEyes:.
    i wondered about range rover seats (I think) the older ones had the seatbelts built into the seats.
  6. Geo
    Jul 29, 2007
    9,860
    6,111
    Mansfield,Notts
    They are almost monthly:Rofl1::Rofl1::Rofl1:
    As far a VOSA and the regs are concerned they have never been aceptable in front seats
    you may remember that not being the case, but vosa have re interpreted not changed the rules:Doh:
  7. motor roamin
    May 23, 2010
    1,535
    785
    Leicester
    Why does that not supprise me, I must admit the last vehicle I had MOTed with lap belts was a 65 Mustang.
    There are Motorhome seats available with the seatbelts attached but goodness knows what they cost.
    Wish mine had those, as mine would strangle me in an accident, oh and those are legal:Eek!::Eek!::Eek!:
    Thanks for the feedback Geo
    All the best Rick.
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Back to my original suggestion then :BigGrin:Are RV seats suitable ? could it be done safely ?I would think that it would be quite an easy job to take the back covering off and fix / bolt through the seat framework :thumb: How many testers would know the difference ? I know it is about safety etc but the testers usually give a visual and good pull on the belt.Come to think of it my passenger seat belt bottom clip point is fastened to the seat base so that it swivels with the seat out of the way. MOT Monday so will it pass yet again :thumb::Rofl1:
    terry
  9. Geo
    Jul 29, 2007
    9,860
    6,111
    Mansfield,Notts
    None, its not in our mandate to test to destruction:Eeek: as you said a slight tug to make sure it wont pull out of the floor or its mount, (quite a few did years ago):Eeek:
    RVs in general also have seat belt mounts at the seat base.:thumb:
    The danger is unless inspected and designed by someone who knows what there doing,I hope I do,the seat back is not suitable for mounting the top parts unless further mods are carried out also
    It could be a simple task to strengthen the back by adding extra steel supports to the floor or base or simply extending the top mount with the use of another seat belt strap to the floor or seat base from the top mount, so that all stress points are returned to where the Manf intended
    The important factors are that the seat back should not be relied upon un modified
    Geo
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    :thumb: That sounds simple enough then :thumb:
    terry
  11. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    And there was me looking to replace my existing lap belts with new ones to match the seats....
    Should I be looking at replacing them with across the shoulder ones then?
    Competition approved mountings are available for welding. Are these mot legal?
    Welding and mounting posts no problem.
    Steve.
  12. Geo
    Jul 29, 2007
    9,860
    6,111
    Mansfield,Notts
    Recent interpretations and the production of a new seat belt checking flow chart by Vosa
    makes it easy to confirm what you need BUT a number of questions need answers as you go through the chart reproduction of the flow chart is somthing im working on so I can post it on here
    Year of first use
    number of passenger seats
    number of foward facing seats behind driver
    and GVW to name just a few:Doh:
    If you had 9 passenger seats in a vehicle over 3500KG you dont need any seatbelts at all:Eeek:
    Edited to remove a possible confusing statment
