rv oven HELP
Discussion in 'American RV's' started by do1977, Oct 29, 2009.
  1. do1977
    do1977 Read Only Funster
    Oct 28, 2008
    86
    where i park up
    i have a oven in my rv it is a magic chef no matter what temp i turn the dile to it burns the pizza has any one else had this??
  2. algill
    algill Funster
    Dec 12, 2007
    644
    214
    Derbyshire
    Don't try to cook your food directly on the shelf above the gas flame. You need a wire rack type shelf which you can put in higher up.
    Gill
  3. do1977
    Oct 28, 2008
    86
    where i park up
    i no that and there is a shelf that i used
    just have to eat out ha ha
  4. muz
    muz Read Only Funster
    Nov 15, 2007
    133
    4
    eastwood notts
    oven
    hi do1977 when you find out will you let me know as dragon burns every b----y thing in ours they are not the same as uk ones.muz and dragon
  5. IanH
    IanH Read Only Funster
    Apr 6, 2008
    159
    3
    Cornwall
    The trick here is to put a pizza stone on the metal plate directly above the flame ,the Americans also use a ceramic tile .
    You will find nothing burns on the bottom and things cook more evenly
    Ian
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,616
    YO11 2BD
    we have a clay pizza plate.
    pop it on the plate, put in the oven and it comes out cooked.
    dunno where we got it though. :Doh:
    is your oven temp control (thermostat)working ok ?
  7. pepe
    pepe Read Only Funster
    Jan 8, 2009
    6
    3
    hi had same problem could not get on with it. i changed mine for a spinflo caprice just had to remove the bottom cupboard which is now the pan store at the bottom of the oven. got it off ebay about £300. regards mick
  8. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Not what you want to hear ... but best advice .. Bin It ,
    everyone I know who had one got rid of it and fitted a British make..
    I have a SMEV fitted. :thumb:
  9. moandick
    moandick Read Only Funster
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    We mastered ours in about 11 months but it was hard work so in the end, like scotjim, we binned it and bought a 'Bush' electrical oven with rotisserie and griddle plate mounted on top.
    Magic - there is nothing quite like a 'joint' properly cooked on a rotisserie - we have to fight the cats for the 'pork crackling' - or the taste of a properly cooked pizza.
    We are looking around for a dish-washer small enough to fit in the space left vacant by the oven - maybe a 'drawer' type dish-washer
  10. pinky85
    pinky85 Read Only Funster
    Mar 30, 2009
    9
    As well as Smev and the other brands mentioned, you can also fit a Stoves oven, they offer an LPG range which you can pick up for best prices from local Narrowboat chandlers. Their 500 DIT model fits in the space of most US RV ovens and includes oven, seperate grill, 4 burner hob with a glass lid (which can be removed if neccessary).
    Bonus being is that with the warranty if anything goes wrong, a nice fella from Stoves will come to you and sort out any problems.
    Personally I would bin the magic chef and replace with a popular European model.
  11. PeteH
    PeteH Funster
    Nov 22, 2007
    2,125
    2,646
    East Yorkshire
    Oven?
    Mine came with only a Hob, binned that and fitted a "caprice" oven £220-00 curtessy of Mr O`Leary (often seen at some shows). No Problem, have just enjoyed part of 2 Pizza`s cooked in it to-night, (the grandson had most of them!!!.
    pete
  12. bashers
    bashers Read Only Funster
    Mar 21, 2009
    108
    Bedfordshire
    If you're not up to binning the oven yet, the owners manual suggests that burnt food is caused by insufficient pre-heat time.
    As the "blow torch" used in this oven warms the interior, the base plate gets much hotter than the desired temp until the selected temp is reached.
    give it a good 10 minutes to warm up properly and cook high up on a shelf and it will be fine
    After burning far too much food, I've not had a problem since i allowed the preheat time.
  13. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,233
    16,838
    Liverpool.
    Quite right, We not only cook but bake in ours, everything is perfect.
    Have heard many times the words,"I cant get on with the American oven."
    If you leave it on for 15 mins before you cook with it,it will be fine.
    Dont forget to convert from F to C though.
Similar Threads
  1. Sarahchris
    304
