RV Lights (1 Viewer)
C
concar
hello all,
i have a 2006 damon daybreak 3272, it will need an mot at the start of next year as i live in N Ireland.
i have been told that the front headlights can be a problem as they are pointing in the wrong direction.
Anybody come across this problem before as our mot centres over here can be strict on these items?
Boo
633
4
Cornwall
A cls
9 years
hello all,
Don't really know your van dude................are they round......oblong or square lights?? got a pic?
Boo
IanH
158
3
Cornwall
5th wheel
If your headlamps have a clear glass the chances are you have the headlamps with a flat beam.
You should be able to just get away with setting the aim to the left with the adjusters
When i imported our 2005 Fleetwood Revolution it had these headlamps and i got them set up in the HGV garage i used to work
I would sugest you find a local HGV garage and get them adjusted before your MOT,much better than a fail
C
concar
sort of rectragle shaped, i will post a picture tomorrow.
have you had any dealings with other rv lights?
Boo
633
4
Cornwall
A cls
9 years
Yes, mine had 4 candle powered lights in when I got her.......2 headlights and 2 main beams and I swaped them all for duel lights so that all 4 come on with the headlights and all 4 have main beam now.................then I parked on a level backroad one night and adjusted them..........they are great now :thumb:
Oh and welcome
Boo
Jul 29, 2007
6,548
39,527
Ipswich
RV and PVC
30 years
Hi in case you don't know you will also have to sort the rear lights as well, if the indicators and brake lights use the same bulb.
Olley
zaskar
1,159
371
UK
5th Wheel
As I understood it, American headlights do not point to either side, they point straight ahead and slightly down, so you shouldn't have to do anything with them.
C
concar
Yes thanks for all your help
I also spoke to a very helpfull man at at stateside tuning & he also said the lights just point straight.
regards
stuart
des
128
south staffs
RV
5 years
james (stateside) is correct. i have a 3272, same vintage. however, the lights are not very bright. recommend having them uprated - but must fit relays as wires are not very thick.
des
