RV Genny problem (1 Viewer)
X
Xoxoc
Hi all,
The onboard genny on my RV is misbehaving.
When I try and start it it fires up fine and sound like it is running okay but as soon as I release the remote start switch - it dies instantly.
If I keep the remote start switch held in - it stays running for longer (30 secs) but then dies even with the button held in.
All the while the light on the remote switch is flashing constantly.
I have half a tank of fuel, full batteries and it worked last time I tried it.
Any ideas what's wrong?
TIA
Bryan
scotjimland
2,316
9,993
A Woosh bang
Prime suspect is * Low oil level
other things to check
* Low oil pressure
* Sticky choke linkage
* Check the generator AC voltage output.
Other voltage tests require an Operating Manual, Troubleshooting charts and learned personnel.
12,263
45,049
Norfolk
Nearly Tugging
Since 2004
Does it start on the genny mounted switch ?
X
Xoxoc
Thanks for all the suggestions - I'll check them out as soon as I can as not near RV at the moment.
Pat, it had a new circuit board recently so that should hopefully be ruled out (hopefully)
Bryan
Loddy
171
3
south west
RV C class
4+ 30 years tugging
The flashing light is a fault code, refer to manual for guidance
Loddy
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
Hi Bryan
On the Generac ? on our truck-camper we eventually went to a generator Co.
There are quite a few circuits to check out that can give your symptons------on mine all were ok--------eventual cure (we hope ) is to replace 1 of the 2 PCBs. (still not fitted as genny has to come out to fit it----a job for when I have time !!------If I remember correctly, the US board controls the Hertz)
Nigel
I hope yours is a simple fix ! !
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
hope you get it fixed quickly and easily and just take care of that back of yours when doing it xxxxxxxxxxx
