Rust (1 Viewer)
Brightonian
187
162
City of Brighton & Hove
8 Years
This is the metal above windscreen
If i try and T-cut it then wax it is there any more i can do to stop it coming back?
Many thanks
Pete
Emmit
8,032
17,740
Cornwall
Pilote Explorateur
Jan.2014
I think the 'only' way to ensure that it doesn't come back in the long run is to remove the windscreen, take the paint back to bare metal, treat and then respray.
Apart from the fact that it's in just about the worst place to get to, paintwise, it's not a 'Big' job.
Emmit
8,032
17,740
Cornwall
Pilote Explorateur
Jan.2014
I realised after I had pressed the 'Send' button that of course, after you have got the window out, then you can sit on the dash to get at the rust.
If you don't go mad with the grinder then you can mask off the paintwork immediately above the windscreen so as to not have to do a heap of spraying.
Brightonian
Brightonian
187
162
8 Years
Don't think i have the skills or confidence to do this:(
I've used Kurust successfully in the past. Also available in larger bottles.
Is it a case of treating the rust with the Kurust then masking along windscreen and painting, or would the windscreen have to come out?
GJH
29,450
38,827
None, now sold
2006 to 2022
I've never used it in a situation where taking a window out was involved but I suppose it depends on the extent. If, as @Ranger says, there is some rust behind the rubber then that would need treating as well. If it is only above the rubber, though, the rubbing it down to the metal and treating the metal before repainting is equivalent to what I have done.
Nov 25, 2013
1,119
1,760
kent
Swift Kontiki 669
Since April 2013
Don't park it facing the sea. If you live in Brighton and it is outside, damage it caused by the salt in the air.
Emmit
8,032
17,740
Cornwall
Pilote Explorateur
Jan.2014
Sorry to say this but to do the job properly, the screen has to come out.
43,319
49,386
And somewhere like autowindscreens or autoglass will remove and refit the screen for a fee....and a damage waiver form filled in and signed.
Autoglass removed, resealed and refitted my RV screen in the past.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That could be serious. Try and ease the rubber away with a screwdriver and look in the joint, the screwdriver will go through the metal if the gods are not smiling on you. If they are smiling you will find nice solid paint and you can clean it up, treat, paint.
Brightonian
Brightonian
187
162
8 Years
Thats interesting didnt know that.
I think i might though look for a quote to do it from body repairer as i got more to be done on the door and bonnet. ( if only i had more skills and confidence:unsure:)
Brightonian
Brightonian
187
162
8 Years
Good idea will have a look tomorrow in day light.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I take it that it is a year old fiat then? Pull the rubber down and look at the metal ladge as the water lies there and rots it quietly then sneaks out and you see it there, usually a lot worse that you think,, Sorry but that is life with metals and sea air.
DanielFord
3,020
3,086
As others have said, a body repair place is probably you best bet, they should be able to do the job at a cost.
43,319
49,386
Looking at those pictures i will stick my neck out and say its already been resprayed but not prepared properly.
Paint does not peel off that easily if its applied properly.
Feb 16, 2013
19,725
51,979
uttoxeter
ambulance conversion
50 years
Yeah that's what I thought, no mention of age or what sort of van doesn't help either
Oct 20, 2014
452
2,537
Wicklow Town, Ireland
2020 Avantgarde 175
A good few years
Ok...Regards the rust....Screen out, grind off rust to bare metal....repaint to seam line just above..... Thats the ONLY way to do the job right....
