Rust on the Towbar
Discussion in 'Auto-Trail' started by pvw10, Aug 14, 2012.
  1. pvw10
    pvw10 Read Only Funster
    Mar 3, 2012
    274
    45
    Gloucester
    Hi all,
    got some rot on each end of the towbar, any others found a decent fix ?
    My thoughts are cut off the white plastic back to decent metal, lose the Black end cap and Black Hammerite it.
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,893
    79,278
    Sutton on Sea
    I've had them go just like that. Your fix is the same as i did
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    I would do it in white hammerite smooth then put the black cap back on :BigGrin:
    terry
  4. Sphgmo
    Sphgmo Funster
    Aug 10, 2012
    58
    29
    Worthing.West Sussex
    We had a problem with the plastic coating bubbling on our towbar.
    I tried many engineering firms to see if the plastic could be sand blasted off.
    But they all came up with the same negative reply.
    They said that when the plastic is sand blasted it simply keeps migrating.
    One (serious) reply was to chuck the tow bar on a bonfire and have the plastic burn off.
    But then again someone said that the heat could affect the integrity of the metal.
    In the end I bit the bullet and bought a new bar!
    • Like it Like it x 1
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,931
    10,301
    unbolt the bar and move it well away from the van first
    take endcaps off if you can, but I think they are heat shrunk on
    take a blowlamp and heat the plastic a bit at a time and strip the whole bar, not just the rough ends. you will probably find rust starting near the mounting bolts too
    polish the metal up and to remove any rust or remaining plastic with sandpaper or even wet and dry. the best finish depends on how well you do this
    either paint with hamerite smooth or get it resprayed using antichip or spray on lining
    refit endcaps if possible or buy push in caps to fit the size bar
    refit to van nice and tight
    that should last a few years or more if you used rubberised anti chip
  6. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,462
    7,373
    Derby
    The plastic end caps are the problem. Moisture gets past the cap, can't escape, metal corodes behind the plastic coating.
    As has been said, grind off plastic to good metal, treat rust and paint - or just cut off ends of bar.
    If you want to replace end caps why not spray-foam ends of hollow bar first.
  7. Sphgmo
    Sphgmo Funster
    Aug 10, 2012
    58
    29
    Our problem started because our Autocruise Starspirit has a long rear overhang and on a couple of occasions the bar grounded and the plastic coating got torn.
