RS_rob
Went for a Run Naked Today
It was Just a Trial
"I whipped it off" the pipe that is & ran to work without the filter Air that is
go on groan if you must but Ive done it before & had no issues what so ever however if the pipe was behing the wheels id certainly think twice.
So my quick test on my Boxer 97 2.5 results are:
A definite improvement in power, where I join the M25 to go to work its a progressive uphill run & I have learnt to not engage 5th as it always results in a drop to 40mph & a change to 4th to avoid breaking the speed limit.
An early change into 5th today & She held speed for loger & started to drop a bit but hampered by a slow moving truck meant a drop to 4th to get round him & that was the only change I made on the way to work.
An Unexpected return to home this evening produced the same results holding speed better & less change downs on the hills in fact none.
I will repeat the test tomorrow on my way back to work but I can report a definitive improvement & have already worked how to make this result permanent.
So watch this space
It was Just a Trial
So watch this space
