Running fridge while wild camping (2 Viewers)
May 19, 2015
258
146
Surrey
Burstner
6 years
Probably a silly question that i should know the answer to but anyway - if camping without hook up do we run the fridge off gas or 12v? We are off to Scotland on Wednesday for our first trip longer than 2 nights and just trying to think of everything we should ask before we go. Any other tips welcome!
Minxy
32,623
66,459
E Yorks
Carthago Compactline
Gas - the 12v won't work without the engine running. :)
Lizi
May 19, 2015
258
146
Surrey
Burstner
6 years
Thank you. Another question - what is the solar panel for?
Minxy
32,623
66,459
E Yorks
The solar panel will help to keep your batteries topped up.
Depending on your set-up it will definitely keep the leisure battery topped-up and if it has a relay/link it will also keep the engine battery topped-up too, usually once the leisure battery is full.
What size panel is it and how many/what size of leisure battery have you got?
DBK
18,006
47,987
Plympton, Devon
PVC, Murvi Morocco
Don't worry you won't need it in Scotland.
But more seriously, it generates power from the sun to top up you batteries. It won't generate a huge amount at this time of year even here in the south but it will help.
Do you know what capacity panel you have? It could be for example 80 or 100 watts.
Lizi
May 19, 2015
258
146
Surrey
Burstner
6 years
I cant remember the details of the solar panel and info in the van. So the leisure battery will run the lights, water pump etc? We have only used it on hook up so far.
DBK
18,006
47,987
Plympton, Devon
PVC, Murvi Morocco
Worth finding out for future reference. The leisure battery normally runs everything when off electric hook up but the solar panel will help keep it topped up. You can but see how long you last but don't let the batteries fall below 12 volts if you can help it. They will go lower but you risk damaging them permanently if they go too far. Start the engine if necessary.
43,293
49,250
Yes, but not indefinately.
You have to learn to be frugal with battery power.
Only use what lights etc you need, dont have them all lit as you might on mains hookup.
If you intend staying put for more than a couple of days you will need some method of recharging, and as already said, the solar panel wont cope at this time of year.
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
A lot depends on how many and what size leisure batteries you have. Worth finding out.
Lots of things will need to use your battery power while off hook up, charging phones etc, toilet pump, water pump, heating.
irnbru
13,511
31,136
Glasgow
Benimar 264
11 yrs
You should take your EHU lead with you so that you can book into a site to recharge your batteries if necessary. Depending on your set up and usage they could be flat after a few days. And thanks to this site I have learned you are not supposed to let your batteries discharge more than 50 %.
Enjoy Scotland, weather is fine today :)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Please remember that flat or discharged batteries will take 2/3 days on EHU to fully charge using your on board charging system (that's providing you are not drawing power from them) and NOT 24 hours or less as many seem to think.............
BravoTwoZero
25
4
Herts
Since 2015
Very helpful advice, I assumed wrongly that overnight would be enough to fully recharge the leisure battery.
6,545
148,875
Pickering
PVC the PUG
We've a 12 volt fridge. We rarely have hook up , so Ralph took this into consideration when looking for one to fit in Pug.
It's ever so good, mind you cost more than the one we have in the kitchen at home.:doh:
Eeyore
362
398
You can make your cassette last longer between emptying ( and conserve batteries and fresh water a bit) if, instead of flushing every time you use it you have a bottle of water with a trigger top handy , with a bit of something smelly in it ( aromatherapy oil, Dettol, whatever) and give the bowl a good squirt after using it.
Don Quixote
2,966
5,258
VW T6 Campervan
Whilst nearly every MH now has a battery charger of sorts what happens is it will start at around 6 or 8 amps at 14.4volts (Charging) for perhaps 1, 2 hours, thereafter that same the charger drops amps and voltage to 13.8 (topping up) to 1 or 2 perhaps 3 until battery returns a voltage to say enough. The voltage of 13.8 is NOT charging the battery (topping up) and therefore the next day when you draw amps it seems that the voltage drop is quicker over the day. If however you have a smart charger (something like a CTEK) it charges at 14.8 or sometimes higher then drops voltage slowly over a period of time and every now and then sends voltage up to 14.8. This in simple terms is conditioning (3/4stage). The best thing you can buy is a good 3/4/5 stage charger (pay good money - get good kit) and your batteries will last for years. Even when your not using your MH you should have the batteries on charge.
6,545
148,875
Pickering
PVC the PUG
Great idea. We shall do that from now on , when wilding.
Thanks (y)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
If your wilding,in Scotland, you will likely be on the move regularly. Use battery 12v when on the move and gas when parked up.
If you are moving on every couple of days you shouldn' t have any problems with power gas or water, even black waste can be rid of quite easily.
Secret is to fill up and dump at every opportunity and in emergencies you can always book into a campsite.
Eeyore
362
398
If you don't want to overnight at a campsite then the C& CC will allow you to use their facilities ( showers, washing machines, emptying and refilling points, charging via EHU etc) for up to 3 hours for £7.10.
Don Quixote
2,966
5,258
VW T6 Campervan
That's very useful to know, thank you.
CWH
5,137
247,344
UK
WildAx PVC
From November 2013
Isn't it lovely to have a forum like this where those of us who don't know can ask very, very basic questions and get useful, straightforward answers.
On behalf of @Lizi , and all other beginners such as myself, THANKYOU to all Funsters who share their knowledge so generously and willingly.
:thanks3:
DanielFord
3,020
3,086
It depends on how long you intend to be away from a hookup. We did 3 days on a single 100ah leisure battery, and we weren't particularly frugal with lights, TV etc.
We have since upgraded to 2 leisure batteries, solar power and an inverter. We haven't yet used it all in anger, since we have hooked up every stay so far.
As others have said, a lot depends on your battery bank, the size of the solar and what you use.
244
305
PVC
Every day a schoolday
Not all c and cc sites let you use their service points for the £7.10 fee - double check on the website first.
mikebeaches
5,392
8,592
Bristol
Rapido V68 Van Conversion
Since 2009
Agree with Bobby22 - if you are regularly on the move, touring in the van, and your batteries are in good condition, you shouldn't have any problem. They will recharge as the engine is running.
And as everybody has mentioned, use gas for the fridge when you are parked up.
We went around the Outer Hebrides a couple of years ago at this time of year. We didn't have solar or any extra batteries - in fact just basic standard kit as supplied with the van. No problem whatsoever, even using the diesel blown air heating quite a lot, and which is fairly hungry on 12 volt electric from the batteries.
Have a great trip. (y)
PS. We nearly got stuck in the snow in the Highlands that April, but finally managed OK and it made for some stunning scenery when the sun subsequently came out. ;)
2,575
3,454
Exiled in Yorkshire
Pilote 600L
Since 2006
you do need to be a member to do this though :-S
2,575
3,454
Exiled in Yorkshire
Pilote 600L
Since 2006
I have used this idea for years, there is but one downside, you can use so little water that you can end up with " a bit of something smelly in it "
:-S
