Running fridge from leisure battery
Discussion in 'Tech/Mech General' started by Mags52, Feb 27, 2013.
  1. Mags52
    Mags52 Funster
    Jun 2, 2010
    1,096
    1,179
    Bathgate West Lothian
    Hi All, We're getting a solar panel fitted shortly and intend to tour the Western Isles for a month in June. Last time we camped without hookup we found our gas ran down in a few days using it for fridge and cooking. We're travelling with friends in a car with tents so we don't intend to drive every day. Is it possible (and advisable) to run the fridge from the leisure battery to save gas? At the moment it seems to run from the vehicle battery as it only works when the engine is running.
    If it's possible to change it over how is it done?
    Mags
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,179
    16,641
    Liverpool.
    Sorry but you are looking for the holly grail with that one. Even with a roof full of solar am afraid you would not be able to run a fridge on 12 volt for very long. Get a bigger gas bottle is the answer.
    • Like Like x 2
  3. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Possible .. yes.. advisable No .. even with a solar panel, the fridge will kill a 85ah battery overnight..
    why you ask.. the 12v element is not on a thermostat , so runs all the time.. and as it draws roughly 9amps. x 24 hrs = :Eeek:
    as per Dave's reply.. get a bigger gas bottle or take two
  4. Mags52
    Mags52 Funster
    Jun 2, 2010
    1,096
    1,179
    Thanks folks. I rather feared that would be the case but hope springs eternal. We're on Gaslow but only have one bottle. Maybe this is the year to bite the bullet and have a second one fitted.
  5. scotjimland
    Jul 25, 2007
    28,936
    25,589
    if you have space, why not fit a Calor bottle along side the Gaslow.. ?
    best of both worlds.. and Calor is a easier to find than Autogas in remote areas
  6. Mags52
    Mags52 Funster
    Jun 2, 2010
    1,096
    1,179
    I don't think I would do that Jim as it defeats the purpose of having the Gaslow fitted in the first place. We're two women of a certain age and lifting bottles had become difficult. :Smile:
  7. scotjimland
    Jul 25, 2007
    28,936
    25,589
    I understand..
    but I'm sure you could find a strong gentleman when you need to exchange.. :Smile:
    unless you visit our local sub Post Office where we have the most unhelpful sod you could find ,..:RollEyes:
    • Like Like x 2
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    That seems quite a lot of gas usage. Admittedly we have 2 x 11 kg Gaslow bottles, but in the summer we use at most, one full bottle in a fortnight. We rarely, if ever, hook up to mains and even in mainland Europe with temperatures in the high 20s - low 30s with the fridge running flat out to keep cool (on gas) our we have not used more than one bottle in two weeks. Also, most of the time we use aires, or often wild camp in Scotland so run gas for water heating to shower and wash-up etc. Might some of your gas appliances need checking for correct combustion perhaps?
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Hi Mags the other alternative is a fixed gas tank of a decent size. Ours will last for at least a month in the summer with fridge on 24/7 we never bother to change over to 12v when driving.
  10. maz
    maz Funster
    Jan 26, 2011
    2,530
    2,170
    Out there somewhere
    As others have said, forget about powering the fridge from the leisure batteries. Like JeanLuc, I'm off hook-up a lot of the time in summer and my usage is similar to his. Maybe it's the cooking that's using the bulk of the gas? Good excuse to eat out. :Smile:
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,707
    17,323
    YO11 2BD
    just a thought but the gas thermostat may be faulty and the fridge is running all the time
  12. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    The gas is lit all the time when on gas :thumb: The little gas flame that lot's refer to as a pilot light is IT :Wink::BigGrin: no bigger burners to light and go on and off simply the small gas jet is enough to keep fridge going all the time.It does not even go on and off automaticaly simply stays lit :Smile:
    terry
  13. scotjimland
    Jul 25, 2007
    28,936
    25,589
    That's true Terry.. the temperature is determined by the flame size, which is determined by the setting on the dial..
    but not true if you have a large fridge such as the Norocold that was fitted to my RV ..
    it has a thermostat with an electronic igniter, the gas is ignited and extinguished as required to maintain the temperature.. It has no pilot light.
    • Like Like x 1
  14. Mags52
    Mags52 Funster
    Jun 2, 2010
    1,096
    1,179
    A 6kg bottle is only a little more than half the size of 11kg so that might explain the fact that we can use a tank in a week when using it for everything. I don't know why the fitters didn't put an 11kg in when we asked for one bottle - I'm assuming it's because there wasn't room.
    Will investigate further with a local dealer.
    Thanks all.
    :thumb:
  15. Spidermonkey
    Spidermonkey Read Only Funster
    May 8, 2012
    32
    6
    back in uk for a while
    Would agree with jeanluc - our 6kg gas bottle lasts us nearly 3 weeks using it for cooking, fridge and showering.:Nowink:
  16. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    The 12V electric power is not thermostaically controlled, at least it wassn't on my htree way fridge.
    Get a 12v compressor fridge if you must use 12V.
  17. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,261
    Gobowen near Oswestry !!
    Available in Stornoway !!!:thumb::thumb::thumb:
  18. scotjimland
    Jul 25, 2007
    28,936
    25,589
    as I mentioned..
  19. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,245
    10,744
    E Yorks
    Have you thought about not using the cooker so much and doing more BBQ'ing instead, either using charcoal or a disposable canister type BBQ? You could also get a gas canister type hob too, again to use outside and minimise your on-board gas usage.
    We have one of these for BBQ'ing:
    http://www.ebay.co.uk/itm/MARKSMAN-...NG-GRILL-STOVE-4-CANNISTERS-NEW-/221047217890
    http://www.esellit.com/marksman-tools-portable-camping-23kw-grill-66196c-p-2176.html
    And one of these (different make) for cooking:
    http://www.gooutdoors.co.uk/hi-gear-portable-gas-camping-stove-p142491
    • Like Like x 1
  20. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,449
    Stokesley, North Yorks
    Tried running my fridge off the leisure batteries after reading this thread.
    It definately won't let me. Even with the engine off, if I manually select 12 volt, or let it select 12 volt by itself, it works off the vehicle battery.
    Checked it by watching the voltage drain on the display panel.
    The solar panel didn't get anywhere near keeping the battery topped up.
