Routing solar panel cables on Hymer B690
Discussion in 'Solar Power' started by Wanderingmac, Mar 14, 2015.
  1. Wanderingmac
    Wanderingmac Funster Life Member
    Mar 22, 2013
    16
    Ireland
    Any suggestions for routing solar panel cables from roof to EBL on Hymer B690? The electro bloc is in external locker on near side under the sink. If I could remove the kitchen drawers I may be able to better check a routing. Can these be removed easily? Any help greatly appreciated.
  2. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Wardrobes are good top to bottom routes. Ours has a big cable duct in the back corner ready for such up/down cables.
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    Assuming it's a double-floored model and the EBL is in a locker that is part of the double floor, my advice would be to choose the least obtrusive route down into the double floor then worry about getting it to the EBL. You will have much more leeway once it is in the floor void.
  4. scotjimland
    Jul 25, 2007
    29,041
    25,733
    Suffolk
    • Like it Like it x 1
  5. colinw
    colinw Read Only Funster
    Feb 1, 2015
    525
    306
    Bolton , Lancs.
    Absolutely no help whatsoever , but it will help if you are double jointed and have a pet ferret to pull the cables through ! . good luck .
  6. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,182
    7,047
    West Sussex
    Kitchen draw runners are similar to filing cabinet ones, there is a little latch on the side of the runner once you get the knack they come out easy.
    Most of the wiring in Hymer's is in trunking so try to follow an existing wiring route, best to spend 10 hours planning and a couple doing it. You may find a set of the short cable threading rods useful (the end of one of mine is still under the floor somewhere!).
  7. gillnphil
    gillnphil Funster
    Apr 12, 2010
    974
    4,749
    West Suffolk
    I have fitted 3 lots of solar panels to vans. The routing of wires is the hard bit by far. I came through the roof into the cupboard and down through the cable duct when I did my Hymer van. Its not easy and I was glad when it was done.
    Phil
  8. Wanderingmac
    Mar 22, 2013
    16
    Ireland
    Many thanks for all replies and suggestions even the very humorous ones! Can very much appreciate the sentiments behind the humour having tried working on previous vans!
