Routers
Discussion in 'Computers' started by ShiftZZ, Dec 6, 2010.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,096
    Leicestershire
    My current router has 4 ports,
    I have the following:
    A desktop linked to it,
    B 2 X IP cameras.
    That leaves 1 port spare... I have 3 wifi laptops and Mrs ShiftZZ has 2.
    My question is this, how can I increase the number of ports? I am on Virgin Cable, with a cable modem
    Can I run two routers off 1 Modem?
    Any suggestions would be appreciated.
    ShiftZZ
  2. Mixter
    Mixter Read Only Funster
    Dec 2, 2009
    254
    Keighley, West Yorkshire
    Is it Virgins router? Im asking because ive new one on the way. Theyll tell you if you if you can run two routers off the modem or not.
  3. scotjimland
    Jul 25, 2007
    28,995
    25,691
    Suffolk
    See no reason why not ..
    When I was on Virgin cable (or Blueyonder as it was in 2006) I had a four port router with one port to a PC and a second port connected to an Apple Airport base station , (wireless router ) which I used with two wifi Macs .. worked fine :thumb:
  4. 400ixl
    400ixl Read Only Funster
    Sep 14, 2008
    381
    8
    Norfolk
    If you want these wire connected then just plug an unmanaged switch into the spare connector on the router and then the devices into the switch.
    No need for a router as this will complicate matters. A simple switch is all you need.
    Something like http://www.ebuyer.com/product/132456 will do the job.
    Or were you looking to run a wireless router off of the the cable wireless?
    If so yes you can also do this in exactly the same way.
  5. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Could you not use an Ethernet switch box for some of you ancillaries? it may be the cheaper way to go.
    Doug...
    Just posted to see that 400ixl beat me to it...
  6. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Totally agree...
    An ethernet Switch is the way to go.
    A wireless unit would also work.As long as they were all on the same ipaddress scheme/subnet.
