Round 3 pin socket, what is it??
Discussion in 'Tech/Mech General' started by redstar, Jan 23, 2010.
  1. redstar
    redstar Read Only Funster
    Jan 6, 2010
    15
    Stafford, Midlands
    I have an old Auto trail (1988) and have this curious
    beast next to a 'normal' UK spec single socket.
    Could anyone give me advice on what it is / does.
    Looks like a standard socket, however the pins are
    round, and are closer together.
    Thanks in advance chaps!!
  2. smifee
    smifee Read Only Funster
    Jun 18, 2008
    162
    3
    chandler's ford
    hi redstar
    I think it's an old fashioned 12v socket. I used to have a couple of adaptors with the round 3 pin one end & a cigar lighter socket on the other.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,248
    17,920
    YO11 2BD
    does it look like this.
    same physical size as the normal 230v socket
    [​IMG]
  4. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    92
    Plymouth
    Gos:Eeek:h that brings back memories of years long gone by!
  5. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,053
    3,464
    Eastbourne East Sussex
    That looks like a 5A mains socket.
    They look old fashioned but they are also used in modern wiring as we have several of them put in when our house was rewired a couple of months ago to run table/standard lamps that are switched from a wall switch.
    I suggest you don't plug in any 12v appliances till you check they havent got the mains on them :stopsign:
  6. pappajohn
    Aug 26, 2007
    30,248
    17,920
    YO11 2BD
    yep !!!
    thats why i asked if those were the ones.
    someone may have been on the cheap using one as a 12v socket.
  7. redstar
    Jan 6, 2010
    15
    Stafford, Midlands
    Yes it does look exactly the same as that! (apart from the screws
    to hold it onto the patress are top and bottom).
    UPDATE:
    it is 12v supply, not using the 'bigger' pin contact.
    looks as if it was done at the factory, well the wiring
    at least. Think it has to go mind! Does anyone use 12v
    sockets/plugs as fixed equipment on here? Just trying
    to 'justify' its existance really as it has another socket (12v)
    above it by 1.5ft but with a DIN fitment.
    Thanks again troops!
  8. pappajohn
    Aug 26, 2007
    30,248
    17,920
    YO11 2BD
    certainly ugly in a motorhome but what will you replace it with ?
    i dont think the factory would fit it and a modern 12v socket above it.
    chances are a previous owner has fitted it in place of the original.
    you could buy a modern, made for purpose 2 blade socket, otherwise it will be a blank plate which will look even worse.
    personally id fit a modern one as you never know when you may need a second supply...ie: tv AND digi/sat box when off hookup.
