Rotten Oil Pan (sump)
Discussion in 'Fiat' started by Jean-luc, Jun 8, 2015.
  1. Jean-luc
    Jean-luc Funster
    Aug 15, 2014
    104
    69
    My MH is on a 2005 Ducatto 2.8 JTD.
    When going through its Roadworthiness Test (= UK DOE) the tester said its sump was so badly rusted and should be replaced asap.
    Back in March when getting the oil changed the mechanic used a machine to suck out the old oil as he was afraid to open the sump plug incase the whole lot came away :eek:
    On inspection it appears it is rusting from beneath the paint, no scrapes or scratched just the paint bubbling. (see pic)
    It must have been made from sh1te metal first day.
    Has anyone else come across a sump rusting away after only 10 years, it's never been on a salted road, hasn't seen very many wet roads either.
  2. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,685
    3,266
    Cumbria
    Common problem on Fiat, lots of replacement sumps on ebay :(
  3. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,234
    12,888
    somewhere
    looks like it needs a wire brush surffice rust and treated with http://jenolite.net/ then panted with black paint
    bill
  4. mikekaren2
    mikekaren2 Funster
    Dec 5, 2013
    314
    246
    Somerset
  5. berni109
    berni109 Funster
    Sep 10, 2012
    316
    264
    worcester
    When i changed the oil the other day (x250 2007) i noticed some nice rusty patches on the sump and i recalled reading something about this in the past.
    Gave it a coat of hammerite but only had 'post office red' so thats its new colour.
    • Like Like x 1
  6. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,677
    UK
    Yup I had one go. Luckily a cheap repair using a part found on ebay. Just make sure you get the right gasket :doh:
  7. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,608
    1,668
    Stretford
    I was wax oiling underneath my van (Fiat) recently, and the garage where I was using the ramps in comes the local guy who does the MOTs for them, told me to put plenty at the very front (where it bolts to the engine) of the sump as he said he sees lots of them come in with rust all along the front due to the water spray
  8. denisejoe
    denisejoe Funster Life Member
    Aug 6, 2014
    1,219
    891
    Isle of Sheppy
    It's not just the sump it the front cross-members that rust as well; normally on top where you can't see it.
    Joe
  9. Jean-luc
    Jean-luc Funster
    Aug 15, 2014
    104
    69
    • Like Like x 1
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,940
    17,608
    YO11 2BD
    Absolutely pointless wire brushing and repainting unless you completely eradicate ALL the rust using a proprietery rust eater first.
    the rust will simply continue to spread under the new paint.
    For piece of mind its cheaper to replace than find, one day, as you drive you have lost your oil.
  11. DiggerJon
    DiggerJon Funster
    Jan 25, 2013
    586
    5,307
    Dorchester, Dorset
    One Fiat, one rusty sump, one rusty cross member - all only 7 years old. Put me off ever owning a Fiat again (along with broken radiator, alternator, front discs and pads after only 12000 miles and and and ....... - and don't get me going about the four sheets A4 snagging faults I had with the Swift coach(un)built part.
  12. Allanm
    Allanm Funster
    Jun 30, 2013
    3,139
    4,281
    Cotes d'armor, France
    We bought a new Fiesta years ago.When it was about 4 years old, one day I noticed oil under the car. After clambering underneath to have a look, I could see oil dripping from the sump wall. It had rusted through completely.
    We were due to travel a couple of hundred miles the next day, so I cleaned the sump the best I could and applied plastic metal to the rust. I replaced the sump a few weeks later, the plastic metal was still doing its job, but new oil leaks were appearing along the sides.
    Never thought I would ever see a sump rust through..Always a surprise with a Ford!
