Rooflights (1 Viewer)
Petedaniel
18
Swindon
Coach Built
10 months
Hi my Roof lights on my 1958 Autosleeper Amethyst are now showing wear and tear I.E Cracks on the outer casing, as I don't really want to replace them as the rest of the lights are in very good condition, does anyone know if it is possible to just replace just the outer cover?
Pete
icantremember
8,328
17,540
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Hi my Roof lights on my [HI]1958[/HI] Autosleeper Amethyst are now showing wear and tear I.E Cracks on the outer casing, as I don't really want to replace them as the rest of the lights are in very good condition, does anyone know if it is possible to just replace just the outer cover?
Pete
After nearly 60 years I'm not surprised:winky:
I don't think you can buy just the outer shell for the roof lights.
P
Petedaniel
18
Swindon
Coach Built
10 months
Hi my Roof lights on my 1998 Autosleeper Amethyst are now showing wear and tear I.E Cracks on the outer casing, as I don't really want to replace them as the rest of the lights are in very good condition, does anyone know if it is possible to just replace just the outer cover?
Pete
looks like I got that wrong it's a 1998 Amethyst not 1958
TheBig1
17,606
43,111
yes you can buy just the domes, but the plastic arms and springs and their mounts go brittle over the years. its really not difficult to replace the whole skylight and can be done diy in about an hour and a half including tea break
unscrew the lower frame and blind
unscrew the clamps holding the skylight in
from outside use an old credit card and cut through the old mastic whilst gently pulling the skylight upwards. eventually it will just pull straight out
clean away any old mastic left behind using the credit card as a scraper
then clean the opening thoroughly with white spirit
stop for a cup of tea
apply a strip of mastic around the edges of the new skylight
make sure its pointing in the right direction, then place it into the hole left by the old skylight
inside put the clamps in place and start tightening each in turn a bit at a time. but dont overtighten
check the skylight works
fit new frame and blind that came with the new skylight
outside cut off any excess mastic that oozed out
thats it done
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
I dont know whether the Fiamma ones will fit, 24cm x 24cm or 40cm x 40cm
there are plain and clear through top versions
dimensions
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
I would prefer just to change the dome if possible as the interior is still fine.
Not sure if thiselpsbut we contacted Markle and they gave them as the Fiamma ones were the wrong size for our older van. Could not find clear domes which was a disappointment .
P
Petedaniel
18
Swindon
Coach Built
10 months
As long as I can just replace the dome any colour i would be happy
Pete:Sad:
TheBig1
17,606
43,111
not particularly cost effective, but here you go
Broken Link Removed
P
Petedaniel
18
Swindon
Coach Built
10 months
Broken Link Removed
Thanks for that as I live close to the seller who wants £13.80 postage, I offered to pick them up my self. and was turned down. Now I am left wondering what's going on Pete
