Roof Top Boxes
Discussion in 'Tech/Mech General' started by RogerD, Sep 18, 2007.
  1. RogerD
    RogerD Deleted User
    I am looking for some more storage capacity, plenty of motorhomes have roof boxes and I have some questions about them.
    Are they a good idea?
    Do they reduce the MPG by much?
    Are they easy to fit, do I need to drill holes in my roof?:Eek!:
    And why are they so Expensive :Angry:
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Definately YES IMHO
    Not as I would notice.The airstream over a Motorhome is pretty well turbulent any way and this box is usually mounted to the rear of the roof.
    Easy to fit.Make a template first.Find a reference point and check there are no light fitments, wiring etc at the points where you're going to drill
    .Mount through cross members on the roof.May requires removal of inner roof sheeting.
    Expensive.I don't know. they tend to be a fair size bigger that car top boxes.Some have gas struts.
    There have been a fair few on ebay recently.
    Steve.
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    Yes
    No
    Yes
    Not always
    because they are Motorhome toys, and they can get away with it,
    Now a serious answer
    You can save pound by looking for second hand there are many about,(e-bay) sometimes they can be stuck to your roof depending on vehicle construction (not wise if you change your mind)
    Or they can be fitted to existing roof rails
    My preference is bolts and adhesive
    Geo
  4. scotjimland
    Jul 25, 2007
    29,036
    25,726
    Suffolk
    Before going on the roof have you considered a Fiamma rear mounted box ?
    Less hazardous and easier to use, no wind drag and no need to drill holes if you already have a bike rack which you don't use.
    Arguably safer too with no chance of it coming adrift.. :Eeek:
  5. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi Geo,
    I prefer Bolts and Adhesive too.
    And silocon sealant around the base of the box to stop any water ingress and prevent the bolts rusting under the box.
    Steve. :thumb:
  6. RockieRV
    RockieRV Deleted User
  7. Geo
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    My experiance of rear mounted boxs is not favorable, the Fiamma unit i used was one of the smaller type, was only ever half full (cos you cant fil lem when they mount sideways) and the only support given is exhaust like clamps and the box split after 3 weeks, complaints were no use as the stock answer would have been you over loaded it:Doh:, the constuction is weak to say the least thats why adhisive and bolts work best, there are no reinforced areas inside to just use bolts
    Hi steve
    I second the silicone use:thumb: Belt, Braces, and a bit of string.
    Geo
    I see the E-bay queen is on the case
    Hi Sharon XX
  8. kands
    kands Read Only Funster
    Jul 20, 2007
    1,286
    13
    Just a word of warning....
    If you mount one to the roof of an RV with an EPDM (rubber) membrane roof covering, silicon will not stick to it.
    Keith
  9. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hmm It stuck to mine.
    I did clean it well first though.
  10. Lindy-C
    Lindy-C Deleted User
    :Eeek:
    It won't stay stuck for long.............
    Watch out for wet patches on your headlining then....you won't know its leaking until your ceiling turns yellow :Sad:
  11. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Mine's rubber but perhaps it's not EPDM Whatever that is.
    I wire brushed it to provide a key to the surface.
    Can't pull it off , Yet anyway. That's after 6 months.
    Will keep an eye on it though.
  12. kands
    Jul 20, 2007
    1,286
    13
    EPDM = Ethylene Propylene Diene Monomer(rubber).
    For a better description see HERE.
    I seriously doubt that silicon will stick to EPDM for long, but yours does seem to have done???? Never mind me, I'm not a Chemist, but I am sure someone will be along soon :Laughing::Laughing:
    Hope this helps
    Keith
  13. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Maybe they used a different compound in those days.
    Remember this is a 1970's motor.
    Was up on the roof last weekend and all seems ok.
    Perhaps they use an oil based compound or an extra waterproofing additive these days.That would explain it.
    Steve.
  14. Lindy-C
    Asphalt perhaps?
    :Rofl1:
  15. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
  16. Geo
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    The realy worrying thing is, whatever they used to stick your rubber/asphalt roof on with.
    Is all that is realy holding your box on :Eeek:
    Geo
    But you did say you like bolts too!!!
  17. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi.
    It is bolted on.
    Hee Hee. The silicon was just to seal around the base.
    :Rofl1:
    Tend to re asphalt it whenever our travelling friends knock on the door with some spare.Have taken out special FIRE cover for the RV.
  18. Geo
    Jul 29, 2007
    9,894
    6,152
    Mansfield,Notts
    The Reds very nice with the white chippings, bit pricey tho, thought about a thatched roof ?seeing as your fire cover is extended:BigGrin:
    Geo
  19. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Tried the thatched roof but the B***dy Birds keep the missus awake.
    Not good news.:Eeek:
