roof repair (1 Viewer)
Gobil
23
hey All, nice website,
recently became the owner of a 93 Adria 540 on a ducato base. there is some water ingress in an area of the roof, concealed by a cupboard. the roof is aluminium, got up to have a look and previous owner must have had a sat dish on the roof, and now the holes are filled with black rubbery stuff, probably silicon or rubber of some sort. scraped this stuff off as it looked dodgy.
I have searched a bit and found no single conclusive answer to reparing an aluminium roof, Eternabond gets some good reviews, any other ideas?
May do some of the seals also as they look tired and worn, any ideas for this, silicon seems like a no-go I am right?
Any thoughts helpful. There is also a some water damage in this area.
Many thanks
G
The vagabond
37
Try Sikaflex
There is a product on the market called Sikaflex, it is an adhesive sealant, properly applied it is very very good, it is however difficult to remove should the need arise.
Hope this is of some help.
The vagabond
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
If its to repair holes in an alloy roof, Flashband is as good as it gets.
Get it from your local builders merchant, it comes in a role, one side is alloy foil, the other side bitumen. Make sure the roof is dry and try to heat up the area with the wifes hairdrier or somthing similar.
Sticks like sh++ to a salvation army blanket.
dragabed
55
is the aluminium bonded to the roof or floating, this will determain the type of repair you need to undertake.
david price
383
27
Bridgenorth
coachbuilt
5 years
There is a product called alto lead ,ali foil one side and non settint adesive on the other.Been on the market a couple of years so more known by trade.We use it for flashing etc on roofs.
Try a local roofers merchant and ask for a sample.This may be big enough to cover holes,but you will need a solid roller to apply correctly.
Otherwise glue a plate over holes with silkaflex as mentioned above or another product we use and i can say does the job is called sticks like s**t.
Dave
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
Hi and welcome to the Fun, I used silkaflex on our roof after a profesional fitted our top box and made a pigs ear of it. worked a treat.
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
Hi & welcome :thumb: use Sikaflex & a bit of ally sheet -- if you use Flashband it will always bleed through any paint you cover it with -- while doing a good sealing job it will put off future buyers
terry
John H
253
24
Anglesey
coachbuilt
3rd year
terry
As above I would use Sikaflex , you can also get a sikaflex remover if you get it anywhere you dont want it. I use it on my boat and wouldnt use anything else.
John
scotjimland
2,324
10,055
A Woosh bang
terry
This would be my preferred method.. :thumb:
G
Gobil
23
thanks for the tips very helpul,
interesting no-one mentioned eternabond. Would silkaflex be suitable for window seals and vent seals?
John H
253
24
Anglesey
coachbuilt
3rd year
Yes, a lot better than silicone, easier to use as well. One thing I will say is once the tube has been opened it will only last a month or so even if you block up the nozzle so it may be wise to plan a whole day of sealing up ::bigsmile: or have a sealing party with a few others.
regards, John
scotjimland
2,324
10,055
A Woosh bang
Sika make a huge range of sealing products.
For caravan/motorhome general use look for Sikaflex 512..
Purpose-designed Adhesive and Sealant for Caravans, Motorhomes and Trailers. Bonds and seals in one. Strong watertight joints. Elastic and non-shrink stay white formulation. Bonds to all normal construction components (except silicone, polythene or polypropylene).
Terry
11,932
9,079
Lincolnshire
Can't remember ;)
Yes it will seal / bond most things :thumb: but on roof vents I use Sikaflex and a bead of GP mastic (general purpose) because it does not stick to some kinds of plastic - sort of belt and braces :thumb: No idea why it does not stick to some kinds but sticks others so I don't take chances :ROFLMAO::thumb:
terry
jenroof
You might use a sikaflex for your aluminum roofing. You better check it and personally repair it for you to make it better.
