Roof rail crossbar ?? (1 Viewer)
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
hi on my dethleffs motorhome there is a roof rack type bar system which is what looks like an oval bar with a slot in it down each side of the roof then there is 2 bars like an I beam that go from one side to the other these have Hymer stickers on them.
i would like an additional cross bar that would just slot in (in an ideal world) without having to fabricate anything myself as i dont wish to have U bolts visible from the side of the motorhome does anyone know where i may be able to source such a part at reasonable cost?
i dont really want to buy a pair as i only need 1 additional one but i suppose if they only come in pairs then it will have to be 2.
cheers
SandJ
1,799
818
North Yorks
Too long lol
cheers
Andy any chance of a few pics and sizes? :thumb:
aba
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
will post some pics and sizes when i can get onto the roof (if it ever stops raining) although the fiamma ones look like they may fit but expensive :Eeek::Eeek:
scotjimland
2,309
9,979
A Woosh bang
will post some pics and sizes when i can get onto the roof (if it ever stops raining) although[HI] the fiamma ones look like they may fit but expensive[/HI] :Eeek::Eeek:
like i said... rip off
but a man of your abilities should be able to make a crossbar from a piece of round or square extruded aluminum and fit between the rails without using U bolts ..:thumb:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Pick up some same size box section, with some extra length.
Cut off two lengths, a little wider that the width of the bar.
Drill one large hole in one side of each piece, and weld a nut to the outside of each. Drill a hole for the correct size bolt to fit the nut
Cut off one wall, so you are left with two u pieces.
Weld these u pieces to the correct length bar, so the nut is on the inside of the bar.
Bars should now drop onto existing bars. Mark and remove, and then run a drill through the roof bar, so that the bolt can go through and access the nut.
Remove, treat and paint. Once dry, drop back on and bolt up.
Cross bars, made to measure - COST? around £10!
