Roof Leak solar panel (1 Viewer)
Jul 6, 2012
54
27
Shrewsbury
Just One Year
Yo,
Recently installed 120watt solar panel on my Fiat Sea Dinghy and I have a slight leak through the roof. I have thoroughly sealed the entry gland housing unit bit still have an egg cup full in heavy rain.
My question is whether it is at all possible for rain to travel along the cable through the grommitt flange and egress the roof space.
Pray tell
Neville
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
If it's thorough it should not leak.
What have you sealed it with? please don't say silicone
G
Jul 6, 2012
54
27
Shrewsbury
Just One Year
Solar Panel Leak
Good Lord, must sound extremely thick!
Naw I used that Sikaflex stuff that costs a bomb and goes rock hard in the tube after 6 days so works out at £11.99 an inch!
Techno
Jul 28, 2010
15,475
20,756
May 2010
Sorry George :Blush:
Sikaflex is less than £8 at GoOutdoors :thumb:
If you tape up the nozzle after use it will still be usable for at least a month. When reusing just screw off the old nozzle and fit a new one. I pay about £8 for 50 delivered
If the stuffing gland is the right size for the cable water should not get through.
Did you clean the surfaces thoroughly before the adhesive?
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Flex(ible) wiring with two or more cores can have a wick effect and draw through [HI]moisture[/HI]. But for the volume getting into your van you would need a pressure washer on the end to achieve this :ROFLMAO:
So your problem is the hole through your roof and the sealant(?) you have used.
There's a job for the weekend!
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Is it actually leaking where the cable comes through the roof/gland and running down the cable... ?
If it is, you couldn`t have sealed it 100%...:Sad:
Or is it coming from some where else... ?
In which case you may have broken a seal else where while clambering on the roof to fit your panel...
Destination Unknown
398
835
Anywhere and everywhere
American A Class
Not Long Enough...!!
Water is a wonderfull beasty, it takes no prisoners as it slowly tracks throu the smallest of holes. It could be coming from anywhere. Go back on the roof a recheck all fittings you have sealed and check the rest of the roof also. We check our roof several times a year to make sure all is watertight. Edges,joints and fittings.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Of course the water could be coming in through a leaking joint/panel and it is finding its way into your van via your nice new hole in the ceiling board...
G
Jul 6, 2012
54
27
Shrewsbury
Just One Year
Christ! I thought I was hoping for a 2 minute job. Thanks for all your superb advice.
Fond Regards
Neville:Smile:
G
Jul 6, 2012
54
27
Shrewsbury
Just One Year
Sorry ,my screename is inspired by one of my favourite Wolverhampton Wanderers players who career was tragically cut shirt.:Sad: But underneath it all I am Neville though my real name is Andrew. Wife & friends call me Neville after me dad. Is that cleared up?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Deeper and deeper :roflmto:
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Your obviously both nutters, how to get from sealant to sloshed in two posts::bigsmile:
try sealing the hole first and then sealing the gland down:thumb:
(sober):roflmto:
yokeljohn
37
35
weston super mare.
c class
since 1985
What" destination unknown" said was dead right,after having water damaged caravans in the past i considerd myself quite vigalante for checking all seals and joints,stupidly i did not pull off the plastic strip that covers the screw heads going through the moulding some of the , screws corroded badly letting water into the wood frame work of the roof,i shall be replacing all the the screws with stainless.
regards yokeljohn p.s.have you seen what i posted yesterday under DAMP METER.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
I think Neville, George and Andrew are completely barking, as well as all of their family.​
8,162
11,220
Yr Wyddgrug
Hymer B678DL
Since 2009
Yo,
Pray tell
Neville
Thanks for reminder to check the new panels and gland housing now the weather has changed. Fortunately the Welsh rain doesn't have the penetrating power that yours does. Fingers crossed it stays that way:thumb:
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Thanks for reminder to check the new panels and gland housing now the weather has changed. [HI]Fortunately the Welsh rain doesn't have the penetrating power that yours does[/HI]. Fingers crossed it stays that way:thumb:
Welll.. not unless it has some wool round it !!! :ROFLMAO::winky:
