Roof Cable Entry - a neat solution
Discussion in 'Tech/Mech General' started by Sidney, Feb 22, 2013.
  1. Sidney
    Sidney Funster
    Jan 27, 2013
    1,286
    836
    Stamford
    I have plans to put an Oyster satellite, air conditioning and a couple of solar panels on my roof. That's three or four holes that I'd have to worry about.
    Then I saw this...
    [​IMG]
    Neat huh?
    • Like it Like it x 4
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    very neat but not a lot of entry points that I can see. Where does on find such a box though? do you have a link please.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    I used a similar box but the addition of the 'through the roof' tube is a good idea.
    dont forget to use a seperate cable gland for each cable...more than one cable to a hole and it wont be waterproof....and a thin film of silicon around the rubber seal will help, you wont need to be back in there again hopefully.
  4. scotjimland
    Jul 25, 2007
    28,993
    25,691
    Suffolk
  5. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    the angle of the pic is poor Roger....it has 5 knockout holes and more could be drilled in the short edges :thumb:
  6. Gromett
    Gromett Funster
    Feb 27, 2011
    8,256
    15,375
    UK
    It looks great for the coachbuilts with flat roofs. I can't see it working on PVC's though :Sad:
  7. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,224
    15,205
    Leeds the one up North
    Great boxes I've used a few, they're made by CBE Italy.
    I replaced this crap with one
    [​IMG]
    [​IMG]
    • Like it Like it x 2
  8. Gromett
    Gromett Funster
    Feb 27, 2011
    8,256
    15,375
    UK
    Very nice job. Great improvement :thumb:
    This is what I use.
    www.ebay.co.uk/itm/170937376057
  9. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    [​IMG]
    looks like there's been a fire in that one :Laughing:
  10. Techno
    Jul 28, 2010
    14,224
    15,205
    Yes I use those too
    [​IMG]
  11. Techno
    Jul 28, 2010
    14,224
    15,205
    Previous owners hard earned spent on habitation servicing :Angry:
  12. Sidney
    Sidney Funster
    Jan 27, 2013
    1,286
    836
    Stamford
    Great work, very neat and another fine example of why (if you are competent) you should do it yourself. :Smile:
  13. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,921
    12,111
    Taunton Somerset
    :Doh:
    Perhaps someone thought he was:Laughing:
  14. Sidney
    Sidney Funster
    Jan 27, 2013
    1,286
    836
    Stamford
    As this was delivered today I thought I'd provide a little more information...
    [​IMG]
    External Dimensions: 118mm x 90mm. Depth: 30mm
    There is one 19mm precut hole for a compression gland and two more are knockouts i.e. knock them out if you need to use them. One compression gland is supplied this will accommodate a cable up to 10mm in diameter.
    The threaded tube to passing through the roof will require a hole of at least 28mm in diameter. It can accommodate roofs between 15 and 58mm thick. The internal diameter is 22mm.
    :Smile:
  15. G8WVW
    G8WVW Read Only Funster
    Jan 15, 2013
    92
    66
    Cumbria
    Looks great. Like the large sealant contact area between the base/roof and the raised thru-roof boss creates a bit of a dam to hold any small amounts of condensation back from your roof opening. The lid fixing screws also anchor in the base outside of the seal. Very different from the garbage on my roof where previous owner thought oodles of clear bathroom sealant would fix shortcomings of a cheap box!
    • Like it Like it x 1
  16. Techno
    Jul 28, 2010
    14,224
    15,205
    You will need a 30mm hole saw but I've used 32 simply because I have them being a sparky and the locknut handsomely accommodates this
  17. jb0371
    jb0371 Funster
    Jul 8, 2011
    463
    402
    Norfolk
    Teach peole to suck eggs, but I would put a bead of sikaflex on the bottom of the box and around the the down tube just to keep out the water and to add some adhesion.
    I installed a camera on the rear of my van just by buying a big IP66 box from screwfix and some big glands to accomodate the wires.
    Try not use silicon as its not very good long term for outside (wouldnt even trust the external silicone)
  18. Techno
    Jul 28, 2010
    14,224
    15,205
    Yes mine is completely fixed with Sika 512 BUT abrade the box with wire wool before cleaning and sticking it.
  19. Sidney
    Sidney Funster
    Jan 27, 2013
    1,286
    836
    Stamford
    Definitely! Silicon from the DIY sheds isn't good enough for use in the home bathroom let alone a MH. Glaziers do offer better stuff which I use but on the MH it will always be Sikaflex or equivalent :thumb:
