Rollerteam 695 fuse box wiring diagram (1 Viewer)
Gazza333
592
244
Staffordshire
Rollerteam 695
Hi anyone got a wiring diagram for the unit behind the fuse box . I'm looking to tap into the lighting circuit here , I know the fuse numbers but need to know the plugs that the power comes out on. I can have a prod with my multimeter to work it out, just wondered if someone knew already
Cheers. Gary
TheBig1
17,630
43,272
the only people with the wiring diagram and colours is the converter. they dont give that info out normally
the only way is to get in there with a meter and map it out yourself
G
Gazza333
592
244
Staffordshire
Rollerteam 695
I thought that may be the case. Guess ill have to have a prod around with my meter at the weekend. Thanks for the reply
robe
Taunton
Retuning
What do you want to wire up, I fitted an outside light and connected it direct to the output on the control panel, wires already there,
G
Gazza333
592
244
Staffordshire
Rollerteam 695
Hi robe
I've connected it up now , this was from January 2005. I fitted a couple of extra reading lights in the cab . I've seen the connector your on about as that's my next job after fitting two batteries this weekend
Welcome just seen you have joined today.
