Reversing monitor problem.
Discussion in 'Auto-Trail' started by dogman, Oct 29, 2013.
  1. dogman
    dogman Read Only Funster
    Oct 24, 2013
    551
    444
    chepstow
    Hi everyone,
    Just bought a 2006 Autotrail Cheyenne 840 SE on Saturday, great drive home, really pleased with it, spent all day yesterday pottering around, fitting a bracket and a CO2 detector, rugs, made up the beds with new linen etc. etc. you all know how it is. Went out today for the first time, took grandchildren to the Forest of Dean for a trawl round, had a nice day out. Reversing into my space on our return home I found the reversing monitor only gave me some flickering jagged lines across the screen, I got out and checked behind but there were NO flickering jagged lines to be seen only tarmac:cry:. Tried switching it off and on again, also went to the control panel and switched off the power there but no luck. Just dropped an E mail to the dealer, didn't want to ring as it's getting late. Just wondering if anyone has any advice they can offer.
    I have read that these are not the best in the world so I thought I might replace it, found this one on E bay http://www.ebay.co.uk/itm/11-TFT-LE...3?pt=UK_In_Car_Technology&hash=item58a574c9ad
    Can I just use the monitor from this ?
    Will it plug strait in? or
    Do I need to install the complete system?
    How difficult is something like this to install in a motor home?
    Will it give me better quality flickering, jagged lines in full colour or just plain old tarmac?
    Any advice is appreciated and YES I know I need psychiatric help.
    Regards to you all.
    Cal
  2. FM02MZO
    FM02MZO Funster
    Jun 22, 2012
    155
    28
    Castle Donington
    If you only bought it last Saturday I would certainly go back to the dealers,
    We had a 2006 Autotrail Mohican and that worked perfectly after the dealer had spent a few minutes setting it up.
  3. buckby
    buckby
    Sep 6, 2013
    213
    148
    nottinghamshire
    I have a monitor on the interior mirror the monitor on the roof has a din plug style plug on it and the new monitor would not fit this plug. I used the rca plug and ran it through to the monitor control box and plugged it in the bottom av out socket next to where the orignal monitor plugs in i then wired the positive feed to the new monitor to the reversing positve through a three way toggle switch then put permenant live to the other terminal on the toggle switch this allows the monitor to come on when reverse is selected also I can have it on permenant when towing the car also i would check the din plug into the observe veiw box to make shure it is in tight as when they come loose it causes lines through then monitor hop this helps
    Kev:thumb:
    • Like Like x 1
  4. dogman
    Oct 24, 2013
    551
    444
    chepstow
    I have E mailed him but I might just fit a better one anyway as I have read these are not top quality when new and this is certainly not new but thank you for the advice.
    This is a great deal of help in spite of the fact I only speak English:BigGrin: all sounds a bit technical to me. Clearly you spent some time on your very helpful post and many thanks for it, now if you should be down this way anytime soon could you please..................... No, No, too much to ask.
    I will come back to your post if I should purchase this unit but will persevere with the dealer for now, if he fails to fix the problem I will hunt him down.
    Again many thanks for your help.
    Regards
    Cal
  5. buckby
    buckby
    Sep 6, 2013
    213
    148
    nottinghamshire
    Took me some time to work it all out but I didnt like the position of the original monitor to far back with the mirror one you can glance at it and look in the side mrrors at the same time learnt this after having to rachet strap the tow bar to a tree to straighten it after hitting a cast iron post last motorhome had monitor on dashboard:Rofl1:
    • Like Like x 1
  6. rangitira
    rangitira Funster
    Jun 30, 2010
    6,324
    12,830
    Cornwall
    Have you checked the sensors? Could be a little thing like a spiders web. On my last M/H the thing just HOWLED when I put it in reverse, Mr spider was sitting guarding his web on one of the sensors>
  7. dogman
    Oct 24, 2013
    551
    444
    chepstow
    I will check in the morning, many thanks for your help.
    Cal
  8. dogman
    Oct 24, 2013
    551
    444
    chepstow
    Checked the camera, no spiders but thanks for the advice anyway.
    I did get a reply from the dealer:~
    "You could also check that in the menu, the camera is set to V1."
    It is so the problem is deeper than mere switching, I will fit a new one of better quality and put the job to bed for good (hopefully), just a matter of compatibility.
    Thanks to all for your help.
    Regards
    Cal
  9. Terry S
    Terry S Funster
    Jun 13, 2016
    5
    3
    Salisbury
    In my 2002 Autotrail Scout. Te rear view camera cable had been joinedv in the rear locker inboard from the camera. The wiring needed redoing as was done merely with insulating tape.Its fine now!
    • Like Like x 1
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    Reversing/rearview CAMERA....not reversing sensors.
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,970
    2,801
    Kendal, Cumbria
    There's a very god chance it is a poor connection as Terry S suggests. Connectors will be near the camera and near the monitor - worth a look. Bear in mind that if you do buy a replacement expensive doesn't necessarily mean better quality. I have a Sony 'mini-ball' CCTV camera and one of the monitors sold by all and sundry that clips onto (or in my case replaces) the rear view mirror. Total cost ............ under £40.
  12. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    325
    212
    South Essex
    And after 3 years have passed, I'd have hoped the problem was long fixed :LOL::LOL::LOL:
    Sorry. Couldn't resist....
