Reversing Lights & Sensor Kaput (1 Viewer)
AlphaPets
36
Newport
Bessacar E795
Hi,
I have just purchased a Bessacarr E795 (Fiat Ducato 18 JTD) which has extra reversing aids in the form of lights fitted under the rear section and reversing sensors. However they are not working, nor are the normal factory fitted reversing lights. I can't find a fuse associated with these electrics. Any ideas please?
:helpsos:​
43,323
49,427
dont rely on the cab/engine fuse box 'item' markings...seldom are they all marked in the listed order.
fuse box locations can be under dash or under bonnet or both !
the reversing lights and sensors will use the original factory 'reverse light' fuse and its usually just a case of pull fuses and check with a multimeter set to ohm's/continuity.....dont rely on a visual check as the fuse can be faulty without any outward sign.
before you start pulling fuses make sure you have the dash radio code (if needed)
it could also be the actual reverse light switch on the gearbox....if you can locate it then remove the wires and connect together...see if the lights are on....if they are the switch is cabbaged and needs replacing.
A
AlphaPets
36
Newport
Bessacar E795
Reversing light switch replaced
As many have found, the reversing light switch was the culprit, it has been replaced and is fine.
:ROFLMAO:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
it could also be the actual reverse light switch on the gearbox....if you can locate it then remove the wires and connect together...see if the lights are on....if they are the switch is [HI]cabbaged[/HI] and needs replacing.
As per usual perfectly clear instructions from Pappajohn.........that is right up until "cabbaged"
Checked it in the dictionary and it said.........
Cabbaged..........Mullered / Busted / Kaput / F*ck*d / B*gg*red / Stuffed / US / BO-Laxed / Bollacksed / Nadgered / and it was at this point I began to get the feeling that it might be Broken beyond repair, Yes?
:whatthe: :roflmto: :winky:
43,323
49,427
Correct :ROFLMAO:
