Reversing camera double use?
Discussion in 'Tech/Mech General' started by Douglas, Apr 21, 2009.
  1. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    I have often wondered why reversing cameras don't have some way of moving them into 2 positions, one for reversing and another as a rear view. Its probably illegal but it feels like a good idea.
    What do you think
    Doug...
  2. Kon tiki
    Kon tiki Read Only Funster
    Oct 11, 2007
    490
    North Wales
    There are some cameras that have both a reversing camera & rear view one built in to the one housing. Why would you think it was illegal? You can have the camera doing any job you like it is just an aid. I don't believe there is any requirement for any revering camera only that you have to have wing mirrors.
  3. Boo
    Boo Read Only Funster
    Jan 26, 2009
    636
    4
    Cornwall
    You can buy Monitors that take up to 4 camera's..............or if your very handy with micro-sevo's you could easily knock one up that moves remotely :Smile:
    Boo
  4. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    Well! I think anything which obstructs the drivers view is illegal. that an MOT issue also
    and I believe that no video screens should be in such a position that the driver can view it, which could of course make navigators illegal on two counts.
    I'm not sure on this so I thought it would be a good item for discussion.
    Doug...
  5. Shubberdog
    Shubberdog Deleted User
    How dose a screen differ from an internal mirror? :Eek!:
  6. moandick
    moandick Read Only Funster
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    On most modern RV's it is perfectly possible and legal to have a fourway split monitor accommodating four cameras.
    One screen is the left-hand front wing camera which replaces the left-hand wing mirror during the day (it gets dazzled by headlights at night or in the rain) - put your left-hand indicator on and the left-hand camera comes on and shows you an absolutely blind-spot free view down the side of the RV. A legal requirement nowadays in large vehicles is a 'blind-spot' free sideways rear view.
    The second screen is the right-hand front wing camera (ditto above)
    The third screen is the reversing camera - comes on when reverse gear is selected.
    The fourth screen is the wide screen rear-view camera used for checking the condition of the 'toad'.
    I think that cameras and associated monitors are counted as safety equipment rather than 'entertainment' equipment and as long as you do not have your monitor plugged into a DVD player - you are totally legal.
    Just look at the front side and rear end of many, many lorries and coaches nowadays to see just how widespread reversing cameras have become.
  7. Boo
    Jan 26, 2009
    636
    4
    Cornwall
    They are on my wishlist...............I want one in each waste tank too so I know when they are full :Wink: (as these stupid stupid sensors are crap!!.........how do you clean those things anyway?)
    Oooops............hijacking the post again :Doh:
    Boo
  8. daveyboy
    daveyboy Read Only Funster
    Mar 2, 2009
    87
    cambs
    as far as i am aware you cannot have a reversing camera monitor or rear view display mounted within the swept area of the windscreen. its an mot fail.
    cars and trucks have failed mots because satnavs have been left in the swept area.
    my old truck some years ago had a monitor on the dash and nothing was ever said.
    my new one has it mounted high up over the windscreen and its facility to be left on permanent has been disabled because its a mot fail.
    just take a look at cars with dash mounted tv,s. they do not work when the vehicle is is motion, unless someone has tampered with it.
    now tbh the ministry are probably not that interested in motorhomes but they are pulling up trucks left and right because of all the crap they have in the windscreen, wether its sat navs, open laptops and dream catchers.
    if they were having a quiet day they could target mh,s.
  9. moandick
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    Hi Daveyboy
    In nearly every RV that I have looked at - the reversing screen is built into the dashboard - below the level of the dash top - or in the case of some of the C Class RVs it is mounted behind the drivers sun visor and is only visible when the sun visor is pulled down.
    I cannot see any reason why it should be mounted in the swept area of the windscreen when we have acres of unswept glass ahead of us.
    The big boys toys mounted in the Fleetwood 40ft'ers is connected to the DVD and TV stations but it has a built-in chip which cuts the picture down to a thumbnail - impossible for the driver to see - when the ignition is switched on.
  10. robandwendy
    robandwendy Read Only Funster
    Sep 27, 2007
    21
    SOUTHAMPTON
    A reversing camera is connected to the power from your reversing light. If you power it from your ignition system the camera will work as a rear view camera and be live whenever you turn the ignition on. The monitor for mine is stuck to the windscreen where a rear view mirror is normally fitted and works a treat.
  11. olley
    olley Funster
    Jul 29, 2007
    3,826
    2,380
    Ipswich
    You can buy movable reversing camera's and also telephoto one's, Sony do them I believe, expensive though, I just bought two cheapy's, one looks straight down, the other looks down the road. The monitor has two inputs, so you just select which one you want to use.
    Very handy for reversing up to walls ect, and the other's good for keeping an eye on the trailer and traffic behind you.
    Olley
  12. moandick
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    Just to let you know the answer is ICE CUBES. :Eeek:
    If you want to clean your tank sensors then just before you go out on the road, empty the black tank and give it a good flush. Then fill with about 10 gallons fresh clean water and two bags of ice cubes from your local frozen food dealer.
    As you drive around, the water softens the 'solids' sticking to the sensor glass and the ice cubes slosh about and gently remove it.
    After a reasonable journey, the sludge is all at the bottom of the tank, the ice cubes will have melted and you should have clean sensors! :thumb:
    That cleanliness will last about three or four days, if you are lucky!:Sad:
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,089
    17,759
    YO11 2BD
    got mine on the dash,
    no restricted vision or MOT issues.
    it has two inputs but i only use one......too tight to buy a second camera:Blush:
