Reversed polarity (1 Viewer)
Fermenter
54
19
Lancashire
Burstner
Since 2012
We are going on our first trip across the channel this summer and would like to hear people's views on the above. Specifically if people bother to re-wire a 2 pin hook up link or is it ok not to bother. Thanks.:thumb:
GaryW
158
274
Fleetwood, Lancashire
Since 2012
Hi, we are also on our first trip to France this summer,like you I wondered if a reverse polarity connection was needed.
I took the plunge a made up a connector for a couple of reasons;
1) because I didn't want to end up needing one and not having one.:cry:
2) because I could.:ROFLMAO:
Dead easy to make and gives you peace of mind.
It's just knowing my luck I will only need one if I've not got one. :winky:
icantremember
8,327
17,538
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Some folk on here say that reverse polarity is not a problem which I believe to be true so long as nothing goes wrong with any electrical items you may be using.
So ... I don't want to take any chances and carry all the necessary connectors to be able to correct reverse polarity.
I'm sure someone with more knowledge on the subject than me will explain the pro's & con's.
Brian
Spacerunner
607
197
Hampshire
It only becomes a problem if you have to strip down a mains appliance when its still connected to a live supply.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Two basic points about connecting to EHU in France.
1.You will encounter reversed polarity. A tester is cheap and we leave one plugged in all the time,if it shows that polarity is reversed I have a lead about 12" long that I made up to correct this.
2.You will encounter a connection other than the usual Euro hook-up socket. This will usually be a 2 pin French connection,so I carry a short lead to adapt to this.
Mike.
ehuplad
504
93
North Yorkshire
Hobby 600
its a 2 pin plug, If it is reversed polarity, just turn the plug round 180 deg and refit, it will then be correct polarity.
43,293
49,250
an example of why rev polarity is and isnt be dangerous
normal polarity
1) remove a lit 'bulb' from its holder and stick a finger in the holder...you will get a shock
2) now turn off the light and stick a finger in...you wont get a shock.
now reversed polarity....
repeat item #1......you will get a shock
repeat item #2....you will still get a shock.
the reason.......when performing #2 you are turning off the live supply to the bulb holder so cant get a shock
performing #2 with reversed polarity means you are turning off the neutral supply wire...which means the live supply is indeed still live.
electrical items will still work as intended...lights will still light, motors will still turn the same way and a kettle will still boil.
there is no such thing as reversed polarity....only incorrect wiring by our safety standards.
please dont try this at home...its only an example :Doh:
2657
Can't do that with a French two pin plug as the socket has an earth pin that locates in a hole in the plug. Spain and many other European countries use earth contact strips on the outside of the plug and these can be reversed, a Schuko plug that has both systems will work throughout Europe and is fitted to adaptors bought in the UK.
Be careful when using plug in testers as some (mine) does not show the lack of an earth when showing reversed polarity, so when testing always correct the polarity in order to test for an earth. Lack of an earth connection is also a common problem and IS dangerous.
Fermenter
Fermenter
54
19
Lancashire
Burstner
Since 2012
Thanks to everyone for the replies. It seems that some people think it is best to make up an adaptor in case required. However others have never had a problem. I am still none the wiser but will err on the side of caution just in case.
oldun
747
162
St Neots
VW Campervan
Since 2001
Very misleading advice.
The German Shuko plug has two pins (L and N) and side stripes for the earth connection. This plus IS REVERSBLE.
The French domestic type plu has two pins (L and N) and a hole (earth) to accept the pin on the socket. This plug IS NOT REVERSIBLE.
I carry a short lead with the European blue plug and socket just like a mini ehu lead. This has the live and neutral wires swapped over at one end. This can be placed bewteen the long ehu lead and the motorhome thus correcting reversed polarity no matter what plug on the ehu bollard.
Jan 28, 2008
10,111
18,361
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
we know when polarity is reversed as the leds in the switches glow dimly even when switched off
ehuplad
504
93
North Yorkshire
Hobby 600
Sorry but it if it has a hole for the earth then my 2 pin continental lead, will not have a earth as this is on the outside as in spain. never seen this set up when travelling in France.
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
When you've sorted the hook-up out don't forget your anti gas attack devices.
Brian I'm not sure if you're messing about or are serious. Gas attack devices? Europe is out of range to any North Korean ballistic missiles and surely they'll be nuclear warheads not mustard gas?
I would have thought they'd be better off knowing how to defend against Somali pirates?
Parcverger
Funster - Campsite Owner
Aug 13, 2007
459
443
Parc Verger - Limousin
RV
8 years
When we toured I always had a tester and a pre-prepared polarity reverser in case we found an ehu where polarity was reversed. So when we set up Parc Verger, I followed our (French) electrician around with a mains tester to ensure that there is no reverse polarity here. He did not understand why this was needed until I explained, and now if there is any electrical work to be done he asks me to come with him and check his work!::bigsmile:
Bob
www.parcverger.com
2657
If you have a continental adaptor bought in the UK it should have the Shuko plug which will work in France as well as most other Continental countries because it has both earthing systems ie a hole and earthing strips.
If it does not have the hole then it will not earth in French sockets without the side earth connectors.Your lead could be a domestic lead specific to one country but if it does not have the earthing hole then it is not a universal Continental lead.
ehuplad
504
93
North Yorkshire
Hobby 600
I think we are talking about different things here, i was answering the original question about reverse polarity. if it is what you say, then there will be no earth whether it is reverse or not.
So i do not think that my answer was misleading at all. infact i thing that yours is more misleading as the original question was about reverse polarity.
And as stated by others the electricity should always be checked to make sure there is a earth.
2657
[HI]
[/HI]
This is your original reply and my reply is/was that this is NOT possible in a FRENCH socket. I see no possible confusion from this post.
My consequent posts were intended to clarify the position with regard to the various plugs and sockets in use on the Continent. The Shuko plug can be used throughout Western Europe but even this CANNOT be turned in a FRENCH socket in order to correct reverse polarity.
I repeat if your plug does not have a hole for an earth connecting pin then you will NOT have an earth connection in a FRENCH socket. In my opinion this is far more serious than reverse polarity.
I apologise if my replies have confused you or anyone else :thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
It's a problem with these forums.
If you are doing a job, do it properly. A tester plug costs nothing, a cross over adaptor costs nearly nothing. So buy them both and use them. Just one minute of your time when you hook up and you'll know that you are safe.
2657
It has just been pointed out to me that a two pin socket with earth strips and no hole will not go into a French socket in any case, should have been obvious to me really :Smile:
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
On the seargent unit in my van there is a light which indicates reverse polarity.Does this bassically do the the same job as a tester plug ?
Vlad
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
If you have reverse polarity, it means that the electricity is connected the wrong way round. This means that the MCB is on the neutral and not the live wire, removing the protection. I always check the polarity and have a converter in the van. Better to be safe than etc.etc.
