Reverse Polarity (1 Viewer)
May 24, 2014
654
2,564
North Devon
Autosleeper Kingham
Since 2013
Problem with electric hook up in France. Sometimes when l hook up in a site or Aire in France l end up with the power box in my Accent showing a red light for reverse polarity so no electric. The next night on say another site it works ok but then may fail on another site visit a day or two later. In one of mymany handbooks namely Go Motorhoming (Vicarious Books) they suggest that Reverse polarity is common in France'.....and that 'Reverse polarity will not damage your motorhome electrical systems, appliances etc'. How does that comment sit with fellow and knowledgeable motorhome owners on this site please?
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
i would suggest that most devices will be unaffected by reverse polarity however some may be damaged and I believe there is an issue around fusing of devices in that the fuse may be the wrong 'end'
that of course is completely irrelevant if the control unit for your elevtrics turns off the power when it detects a reverse polarity... you can buy or heath robinson up a cross wired adaptor for your electric cable if you need it (as far as I know you simpoly take an ordinary cable and swap the +ve + -ve one end
D
Deleted member 29692
I suppose you can use a reverse polarity supply if you really want to but it's not really a good idea.
All you need to do is carry a reverse polarity adapter. Make one up or buy from Broken Link Removed All it is, is a very short hook up cable wired wrong - one end wired correctly, the other with L & N the wrong way round. You should probably carry a socket tester as well just to be able to double check.
andy63
4,672
15,017
south shields
None
since 1990
well covered subject on here.. a link to one of them
Broken Link Removed..
if you have a reverse supply and its off a continental 2 pin plug remember its just a simple matter of reversing the plug to put it right as long as the box allows that...or carry a short lead which will do the same thing...make it up yourself or they are available at shops..
ta andy
GeriatricWanderer
1,194
4,199
Ouagadougou, Burkina Faso, just cos I can!
Pop-Top Campervan
45years
What we call Reversed Polarity is normal wiring practice on the Continent as all their switches are double pole so both + and - are cut when switched off whereas UK switches are only single pole.
If your MH is continental built it will be fitted with double pole switches.
If UK built it will have single pole switch.
Reversed Polarity is only dangerous to people if they poke around inside electrical appliances without unplugging them.
It will not damage your MH.
Just make sure your RCD trips when it should and forget RP.
More important is to use a circuit tester to check for an earth but once again, as long as your RCD trips, you are safe.
There are cables that will switch RP but, in my opinion, not worth the hassle.
Just my opinion and I'm sure others will disagree but just ask how many people have been shocked, let alone killed, by RP - the same number as have been gassed. :)
Mar 31, 2014
452
705
Stratford-upon-Avon, UK
BUCCANEER CARAVEL
SINCE 1975
Had a problem on a site in France a couple of weeks ago.I had a shock off my tow bar!Guy next to me did a test and found not only was the socket reverse polarity but there was no earth!!I unplugged my lead and didn't use the electric.We were moving the next day anyway.The site owner said there was no problem!!Not sure what caused the shock but had no problems the rest of our holiday.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Your Hymer will have one. It is likely to be quite near to the 230V input socket. My trip box is in the base of the wardrobe where the Truma is located. It looks like a white rectangular box with a twin-ganged black switch near the top. It is on when in the up position. It is this switch that you normally use to switch on the 230V input once you have plugged in the EHU lead.
Have a look in your Hymer manual for full details. By the way, this kind of trip, fitted by Hymer in 2003 does not have a test button on it.
p.s. I don't worry about reverse polarity, but lack of a good earth on a hook-up point is definitely a reason not to use it.
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
The light will also come on if there is no earth mine did today when I plugged in using a extention , so tryed another and was ok. So looked in the plug and the earth wire had come out.
connect it up all was well.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Reverse polarity is dangerous, firstly the fuse is no longer on the phase conductor along with various other technical reason causing a shock hazard so needs to be addressed
AC polarity isn't right just because it works
Polarity in AC circuits doesn't matter, until it does
9,785
20,149
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Thanks JeanLuc, another superb and prompt reply, many thanks (y)
I`ve just been and had a look and sure enough it`s there in the same place as yours, but I`d never noticed it, or used it ! Should I be using it when connecting / disconnecting EHU ?
PS I read your manual on repairs to Thetford cassette and decided to order a new one ! All that business of putting your hand inside and fumbling around feeling for things to unfasten prompted me to get the credit card out and keep my mits clean and ready of action elsewhere !
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
My 2005 B584 (RHD) definitely did not have an RCD. It had two ganged MCBs: one in the Live & one in the Neutral. I fitted a new box with RCD & two MCBs & divided the various supplies between the new RCBs. The certain way to spot an RCD is that, apart from having a test button, it must also have an earth connection.
JeanLuc
3,304
2,199
Warwickshire
I stand corrected. I was referring to the twin-ganged item that is fitted by Hymer.
Gorse Hill
2,364
1,944
Stretford
Not all RCD's have a functional earth
Feb 22, 2011
9,785
20,149
Hymer B544 A Class
Since 2015
So is that different to an RCD ?
Presumably its adequate for what's required to be safe.
I will get an earthing / polarity tester before venturing across the water.
D
That is not correct. Only certain brands have a reference earth connection. It certainly isn't required to work or a way to spot them.
D
The white box to which I referred earlier is the mains cut-off trip switch. Here is the relevant reference from the handbook:
Possibly they've used the wrong stock photo in the hand book but that isn't an RCD.
D
That about covers it (y)
Everything will still work including protective devices. You might not even know about it until you have a problem.
The biggest danger is if you have single pole protective devices. If the polarity is wrong and they operate they will break the neutral so anything connected to the circuit will stop working but it won't be isolated. All the live parts will still be live.
JeanLuc
3,304
2,199
Warwickshire
No - that is the correct picture and matches what is in the Hymer. I now know that it is not a RCD but a MCB - see my previous post.
Jun 11, 2011
376
435
Somerset
hymer s820
hya i always use a polarity tester where ever we are and have a series of leads to sort it out...the tester i have is an audible one saves running around to check if its right
Feb 22, 2011
9,785
20,149
Hymer B544 A Class
Since 2015
Geebee - That's Louis. Looks can be deceptive, he's got a very strong scavenging instinct and I dare not let him off lead when around picnicers ! One sniff of a ham sandwich and recall, no chance !
Yes he is cute though.
Chris
Gorse Hill
2,364
1,944
Stretford
Now I'm just confused :eek::eek::eek:
Quite a lot of RCD's don't have functional earth lead (usually white in colour not yellow/green) the RCD is looking for an imbalance between phase conductors (live & neutral)
The thing to look for, as stated, is a test button (this simulates a fault condition)
