Reverse Polarity
Discussion in 'Motorhome Chat' started by sylvester1954, Jul 1, 2015.
  1. sylvester1954
    sylvester1954 Funster
    May 24, 2014
    172
    523
    North Devon
    Problem with electric hook up in France. Sometimes when l hook up in a site or Aire in France l end up with the power box in my Accent showing a red light for reverse polarity so no electric. The next night on say another site it works ok but then may fail on another site visit a day or two later. In one of mymany handbooks namely Go Motorhoming (Vicarious Books) they suggest that Reverse polarity is common in France'.....and that 'Reverse polarity will not damage your motorhome electrical systems, appliances etc'. How does that comment sit with fellow and knowledgeable motorhome owners on this site please?
  2. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,544
    2,558
    Trowbridge
    i would suggest that most devices will be unaffected by reverse polarity however some may be damaged and I believe there is an issue around fusing of devices in that the fuse may be the wrong 'end'
    that of course is completely irrelevant if the control unit for your elevtrics turns off the power when it detects a reverse polarity... you can buy or heath robinson up a cross wired adaptor for your electric cable if you need it (as far as I know you simpoly take an ordinary cable and swap the +ve + -ve one end
  3. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,768
    11,830
    Kettering
    I suppose you can use a reverse polarity supply if you really want to but it's not really a good idea.
    All you need to do is carry a reverse polarity adapter. Make one up or buy from eBay All it is, is a very short hook up cable wired wrong - one end wired correctly, the other with L & N the wrong way round. You should probably carry a socket tester as well just to be able to double check.
    • Like Like x 2
  4. GAVLAD
    GAVLAD Funster
    Jul 31, 2014
    640
    622
    West Yorkshire
    I have one of the above reverse polarity adapters as well and got mine off eBay
    • Like Like x 1
  5. andy63
    andy63 Funster
    Jan 19, 2014
    2,065
    7,856
    south shields
    well covered subject on here.. a link to one of them
    http://www.motorhomefun.co.uk/forum/groups/reverse-polarity.27/group..
    if you have a reverse supply and its off a continental 2 pin plug remember its just a simple matter of reversing the plug to put it right as long as the box allows that...or carry a short lead which will do the same thing...make it up yourself or they are available at shops..
    ta andy
  6. GeriatricWanderer
    GeriatricWanderer Funster
    Feb 1, 2015
    982
    3,702
    Port Elizabeth, South Africa
    What we call Reversed Polarity is normal wiring practice on the Continent as all their switches are double pole so both + and - are cut when switched off whereas UK switches are only single pole.
    If your MH is continental built it will be fitted with double pole switches.
    If UK built it will have single pole switch.
    Reversed Polarity is only dangerous to people if they poke around inside electrical appliances without unplugging them.
    It will not damage your MH.
    Just make sure your RCD trips when it should and forget RP.
    More important is to use a circuit tester to check for an earth but once again, as long as your RCD trips, you are safe.
    There are cables that will switch RP but, in my opinion, not worth the hassle.
    Just my opinion and I'm sure others will disagree but just ask how many people have been shocked, let alone killed, by RP - the same number as have been gassed. :)
    • Like Like x 1
  7. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,043
    7,741
    Market Harborough
    Made a reverse polarity cable myself, very easy to do, have only had to use it twice but it's there if needed, I also bought a plug in checker, which I use every time I hook up, even in the UK. (y)
    • Like Like x 3
  8. NickNic
    Jan 14, 2014
    5,768
    11,830
    Kettering
  9. robrace
    robrace Funster
    Mar 31, 2014
    119
    69
    WARWICK
    Had a problem on a site in France a couple of weeks ago.I had a shock off my tow bar!Guy next to me did a test and found not only was the socket reverse polarity but there was no earth!!I unplugged my lead and didn't use the electric.We were moving the next day anyway.The site owner said there was no problem!!Not sure what caused the shock but had no problems the rest of our holiday.
  10. Figaro
    Figaro Funster
    Feb 22, 2011
    985
    783
    Newcastle under Lyme Staffordshire
    I`m not sure that I have one in my recently acquired 2003 Hymer, I`ve not seen anything that looks like one, where would it be ?
  11. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    Your Hymer will have one. It is likely to be quite near to the 230V input socket. My trip box is in the base of the wardrobe where the Truma is located. It looks like a white rectangular box with a twin-ganged black switch near the top. It is on when in the up position. It is this switch that you normally use to switch on the 230V input once you have plugged in the EHU lead.
    Have a look in your Hymer manual for full details. By the way, this kind of trip, fitted by Hymer in 2003 does not have a test button on it.
    p.s. I don't worry about reverse polarity, but lack of a good earth on a hook-up point is definitely a reason not to use it.
    • Like Like x 1
  12. laurieash
    laurieash Funster
    Jan 29, 2014
    601
    356
    HALIFAX
    The light will also come on if there is no earth mine did today when I plugged in using a extention , so tryed another and was ok. So looked in the plug and the earth wire had come out.
    connect it up all was well.
  13. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,614
    1,673
    Stretford
    Reverse polarity is dangerous, firstly the fuse is no longer on the phase conductor along with various other technical reason causing a shock hazard so needs to be addressed
    AC polarity isn't right just because it works
    Polarity in AC circuits doesn't matter, until it does
    • Like Like x 3
  14. Figaro
    Figaro Funster
    Feb 22, 2011
    985
    783
    Thanks JeanLuc, another superb and prompt reply, many thanks (y)
    I`ve just been and had a look and sure enough it`s there in the same place as yours, but I`d never noticed it, or used it ! Should I be using it when connecting / disconnecting EHU ?
    PS I read your manual on repairs to Thetford cassette and decided to order a new one ! All that business of putting your hand inside and fumbling around feeling for things to unfasten prompted me to get the credit card out and keep my mits clean and ready of action elsewhere !
    • Like Like x 1
  15. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,090
    2,931
    Kendal, Cumbria
    My 2005 B584 (RHD) definitely did not have an RCD. It had two ganged MCBs: one in the Live & one in the Neutral. I fitted a new box with RCD & two MCBs & divided the various supplies between the new RCBs. The certain way to spot an RCD is that, apart from having a test button, it must also have an earth connection.
  16. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    I stand corrected. I was referring to the twin-ganged item that is fitted by Hymer.
  17. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,614
    1,673
    Stretford
    Not all RCD's have a functional earth
  18. Figaro
    Figaro Funster
    Feb 22, 2011
    985
    783
    Now I'm just confused :eek::eek::eek:
  19. GeebeeJaybee
    GeebeeJaybee
    May 28, 2015
    293
    346
    St Helens
    I
    was too - so to be sure last night ordered a tester (tests polarity and earth) and reverse polarity adapter. Better safe than sorry.
    Jen
    • Like Like x 1
  20. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    The white box to which I referred earlier is the mains cut-off trip switch. Here is the relevant reference from the handbook:
